left channel suddenly out of balance [resolved]
kill_surf_city · 24985
Offline kill_surf_city
Reply #15 on: July 10, 2022, 05:07:33 PM
Turn up that heat!
Okay, i re-flowed every joint and im still getting 178-180mV on KregA. Heat on my iron is up as high as it goes.
Reply #16 on: July 10, 2022, 07:07:27 PM
Are both halves of the 12AU7 glowing?
Reply #17 on: July 14, 2022, 11:59:27 AM
sorry it took me a bit. but yes, both sides are glowing. I even swapped out the tube that came with the kid and put in an RCA.
Reply #18 on: July 14, 2022, 12:03:05 PM
The next thing to do would be to set your meter to beep when you touch the probes, then start probing all the pairs of all the transistors and the 431 regulators on the board above the D socket to see if any of them are internally shorted.
Reply #19 on: July 14, 2022, 12:12:21 PM
I'm not sure my meter has that option. Also, I probing around a min ago and caused another spark. this time at the resistor at reg on side B. Now none of the LEDs turn on and the voltage on side B is now siting around 170v while on side A it is still at 260v
Reply #20 on: July 14, 2022, 12:41:11 PM
Both of the 100KΩ 3W are beeping on opposing ends. Also one end of each of the 0.1 μF 400V film capacitors, the 431 resistors on side B and A as well as the 2.49KΩ resistors
Reply #21 on: July 14, 2022, 01:19:14 PM
Also, I think I may have figured out where the issue was in the first place. The wire connected to D8 wasn't soldered so well, but while i was probing and trying to find an issue with a resistor I caused those sparks that I'm sure shorted out one or even all of the resistors that are now beeping. Let me know which one's I should buy replacements for.
Reply #22 on: July 15, 2022, 05:26:18 AM
If a resistor shorts, typically it will burn itself up in the process.  If that hasn't happened, then the beep may be an instantaneous beep that goes away after a short time due to a capacitor charging.
Reply #23 on: July 15, 2022, 06:30:36 AM
The beeps I get are continuous until I remove the probe. When you say “burn up” would this be something I can see on the resistor? Also should I hold the probe on the resistors that are beeping for a while to see if the beep stops?
Reply #24 on: July 15, 2022, 06:34:47 AM
Yes, and we also would expect the resistor to fail to a state that's completely open.  Keep in mind that you need the probes across the part itself, not one probe on ground and the other probe poking around the circuit.
Reply #25 on: July 15, 2022, 07:07:22 AM
Ohh okay. I was attaching my black ground clip to the ground near the power switch and then probing the lead of each resistor with the red probe. But you’re saying I need a probe on each of the of the resistors correct?
Reply #26 on: July 15, 2022, 07:12:23 AM
You need to probe each pair of pins on all the solid state devices (transistors and regulator chips).
You do not need to probe the resistors.  A blown resistor avails itself with sounds, sights, and smells.
Reply #27 on: July 15, 2022, 07:22:27 AM
Okay so you’re saying on the underside of the board I need to probe the points where I soldered them in? Sorry I’m just confused by what the “pins” are.
Reply #28 on: July 15, 2022, 09:29:54 AM
Yes, the pins of the transistors and regulators are the leads that are poking through the bottom of the PC board.
Reply #29 on: July 16, 2022, 01:15:13 PM
Okay, so I disconnected the board and took it off, flipped it over and probed those regulators. The LM431 regulators give me a constant beep as long as I hold the probes on any two pins. Same goes for when I probe the PN2907A pins. The pins on the MJE5731A on side B also give me a constant beep and ones on side A give me the same but with different pins being probed. Does this mean all of the regulators and transistors are shorted and that I need new ones?
