Please Help. I'm so frustrated.
Evilpancake1 · 3903
Offline Evilpancake1
on: July 16, 2022, 02:53:55 PM
First time Crack builder here and I've run into an issue I can't seem to solve. I'm on the Power Transformer Seceondary Test and it keeps reading 0 volts. I've gone over the soldering twice now and it continues to read 0 volts. I'm not sure what I've done wrong. To add to this I redid the first test, Powerline Voltage Test, and that is also reading 0 volts now too.
Online Jameson
  • Intern in Chief
Reply #1 on: July 16, 2022, 02:59:19 PM
Did you check that the fuse is in place and not blown?
Jameson O'Guinn
Managing Partner
Reply #2 on: July 16, 2022, 03:21:33 PM
The fuse is blown, the middle part is missing. Do you have an idea of how I might have blown it?
Reply #3 on: July 16, 2022, 03:45:00 PM
Do you know what kind of fuse i should buy? I know the manual say 1a fuse, but what size should I buy/what brand would you reccomend?
Offline kgoss
Reply #4 on: July 16, 2022, 04:55:08 PM
If you have the fuse in the square box it is not in the circuit. That is a spare fuse holder. Make sure it is in the bottom clip. Fuses blow because there is a short to ground. If you have the fuse in the clip then post pictures of your build and maybe someone will spot the problem.
Ken Goss
Reply #5 on: July 16, 2022, 05:38:45 PM
Is your meter set for AC volts?
Reply #6 on: July 16, 2022, 06:00:11 PM
My meter is set to AC
Online Jameson
  • Intern in Chief
Reply #7 on: July 16, 2022, 09:37:24 PM
Post some build photos.
Jameson O'Guinn
Managing Partner
Reply #8 on: July 17, 2022, 04:26:09 AM
Pictures of the fuse and Crack
Reply #9 on: July 17, 2022, 06:26:06 AM
You'll probably find this helpful:
It's hard to tell with certainty from your photos, but when you read "attach" in the manual, it means pass the wire through the hole and at least bend it up against the face of the terminal so there's a place for the solder to go.
What kind of solder and what kind of iron are you using?
Reply #10 on: July 17, 2022, 07:43:22 AM
I'm using a 40 watt soldering iron and 60/40 solder like the manual recommended
Offline Gizur
Reply #11 on: July 18, 2022, 12:48:56 AM
The power switch looks a bit 'melty' as well... may need a new one and watch the video on soldering it without damaging it
Reply #12 on: July 18, 2022, 01:04:13 AM
Replacing the fuse fixed Powerline Voltage Test. The test is reading 122V, but it's still failing the Power Transformer Secondary Test.
Reply #13 on: July 18, 2022, 01:05:51 AM
I won't lie the power fuse is a but melty now because I've redone the wiring three times now. It still works, and hopefully will continue to do so, it just looks really bad
Reply #14 on: July 18, 2022, 01:11:59 AM
I'm not sure what I've done, but it is now passing the Secondary Test. Thank you folks for your help.
