Bottlehead Kits
Crack
Left channel RCA jack not passing resistance check
Shackney1127
493
Shackney1127
Jr. Member
August 02, 2022, 10:33:57 AM
Finished building the Crack. Did resistance checks. Only thing that doesn't pass is the left rca jack. I get no resistance. My multimeter actually beeps sometimes. To my knowledge, this indicates a short. Any tips or advice?
Doc B.
Administrator
Hero Member
Re: Left channel RCA jack not passing resistance check
Reply #1 on:
August 02, 2022, 12:51:31 PM
The most common issue is a solder bridge between the outer shell and the center pin of the jack.
Shackney1127
Jr. Member
Reply #2 on:
August 03, 2022, 01:15:59 PM
That looks like the case. Tried removing as much as I could with solder wick, but no dice. Guess I'll just order a replacement and try again.
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
August 03, 2022, 04:58:24 PM
You can also cut the solder off with side cutters or use a small flat head screwdriver to scrape it away.
Bottlehead Kits
Crack
