voltage measurement problems after output upgrade BeePre 2
denteom · 47770
Offline denteom
Reply #45 on: February 09, 2023, 05:43:25 AM
OK, thanks for the tip. I'll try to check on it during daytime, so I can have more light. Hope that will be my last issue. Give you a feedback in a day or two.
Offline denteom
Reply #46 on: February 19, 2023, 02:09:16 AM
Thanks got everything sorted out, My Beepre2 is singing so beautifully.  On to the next Bottlehead kit!
Offline denteom
Reply #47 on: February 19, 2023, 03:36:43 AM
Just a last minor problem, I still sometimes get a loss of signal on the left speaker.  But this time just doing light tapping on the fine knob at 0 db will already do the trick (no need for wiggling the knob).  It sometimes occurs after playing music for awhile like 5-10 minutes. Hope that goes away through time.
From our last exchange of text, I really did not find something shorting it.  What I did last time was just loosened and re-tightened (but not too tight) the screws holding the assembly of attenuators to the chassis. Somehow things improved with that maneuver.
But still randomly I run into that problem. Once I get back the sound the left channel, sounds really balanced and no distortion.
Overall the Beepre 2 sounding really fantastic!
