News:
March 31, 2023, 07:02:53 PM
Author Topic: Output Capacitors Post Upgrade  (Read 453 times)
Offline ashbrook.m
« on: January 31, 2023, 04:08:49 AM »
I am building a shopping list for future output cap upgrades. I noticed that there is no circuit schematic for the second upgrade included in the instructions. Am I correct to assume that I would need 6 - 10uF 250v capacitors to do a complete replacement of capacitors in the audio circuit? Two on the 300b’s, two across the rca outputs, and two across the balanced outputs?
I am contemplating ODAM’s at least across the 300b’s due to size constraints under the pcb.
Re: Output Capacitors Post Upgrade
« Reply #1 on: January 31, 2023, 04:18:37 AM »
You can get away with four if you don't plan to use the balanced outputs.
