Crack w Speedball, Final Voltage issues [resolved]
jonathan.lesser · 1494
Offline jonathan.lesser
on: March 05, 2023, 06:44:14 AM
Prior to Speedball, all voltages good, sound good.
After Speedball, Noise and no music left, right great
Following voltages:
OA: 62V
OB: 99V
G: 0V
B+: 176
All LEDs on
Thank you
« Last Edit: March 06, 2023, 05:12:07 AM by Paul Birkeland »
Reply #1 on: March 05, 2023, 07:00:35 AM
What are the voltages on the front C4S board?
Reply #2 on: March 05, 2023, 08:19:43 AM
Thanks so much Paul!
Terminal one: 64 V
Terminal 2: 185 V
Terminal 3: 0 V
Terminal 4: 185 V
Terminal 5: 0 V
Terminal 6: 0 V
Terminal 7: 102 V
Terminal 8: 0 V
Terminal 9: 66 V
Terminal 10: 0 V
Jon Lesser
« Last Edit: March 05, 2023, 08:22:55 AM by jonathan.lesser »
Reply #3 on: March 05, 2023, 10:47:54 AM
Was terminal 5 0V when you first installed the front C4S board?  When you resolve why terminal 5 is 0V, terminal 9 will move to what it's supposed to be.
Reply #4 on: March 05, 2023, 11:06:18 AM
Yes Paul, all voltages were spot on for the initial crack build
Reply #5 on: March 05, 2023, 11:27:52 AM
If you remove the 6080 and just run the amp with the 12AU7, does that voltage at terminal 5 increase?
Reply #6 on: March 05, 2023, 12:18:38 PM
Thank you, Paul, I will try to do a deep dive over the next couple of days to answer your question regarding the tubes and to focus on problems I may have caused during the upgrade. Thank you so much once again for your enormous expertise.
Reply #7 on: March 06, 2023, 04:30:37 AM
All fixed! Found something dumb and addressed it. It sounds glorious and I appreciate your expertise, Paul, plus your endless patience.
Jonathan Lesser.
Offline Deluk
Reply #8 on: March 07, 2023, 02:35:53 AM
Dumb or dumber, please let us know what you found. We all make mistakes or do something silly now and then.
