fluttering sound on crack [resolved]
ross munro · 2326
Offline ross munro
on: March 06, 2023, 12:33:32 PM
hi  i am getting a fluttering sound on the left channel of my crack it sounds like birds wings this also accompanied by a rice crispies static sound which happens occasionally ,yhe fluttering is permament.i thought id done a decent soldering of my crack but im not so sure now hope you can help
« Last Edit: March 07, 2023, 12:54:02 PM by Paul Birkeland »
Reply #1 on: March 06, 2023, 12:37:59 PM
Start with cleaning the tube pins.
Offline ross munro
Reply #2 on: March 06, 2023, 12:45:35 PM
i have some de oxit would that be suitable. quick question what headphone kit should i be buying for the audeze lcd2 classic  many thanks
Reply #3 on: March 06, 2023, 12:57:47 PM
Yup, deoxit is fine. For critical applications like mic pres in studios I like to chuck up half a Q tip in a dremel tool and use some metal polish on tube pins. If that doesn't solve it you might want to try a different tube.
My choice for the LCD2s is the S.E.X. amp. Plenty of power and a nice match sonically.
Offline ross munro
Reply #4 on: March 06, 2023, 01:03:04 PM
many thanks .have you come across THE GREAT BRITISH VALVE PROJECT its worth a look a group of volunteers have put brimar valves back into production
Reply #5 on: March 06, 2023, 01:35:52 PM
The sound of bird wings could also be wireless interference from a nearby device.  WiFi routers are particularly likely to cause this kind of noise, and a few extra feet of separation can resolve the issue usually.
Offline ross munro
Reply #6 on: March 07, 2023, 11:27:03 AM
have cleaned all valve pins and that has cured the crackling .ive made a new mains lead  to move the crack away from my router and that has cured it.many thanks for all your help regards  mike haywood
