xr out of Beepre 2
denteom · 12957
Offline denteom
on: March 16, 2023, 03:31:38 AM
Can the XLR out of the beepre 2 drive power amps through its' XLR in?  My power amp does not have a sound output when I connect it to xlr to xlr.  But using the RCA out of the Beepre 2 and connecting it to the XLR in of the poweramp using a cable with XLR - RCA drives the power amp properly.
I don't think the XLR out of the the Beepre 2 is the problem, because connecting the Beepre 2 XLR out to a headphone amp with XLR in, plays nicely.
My power amp is a Class D amp Purifi.
Reply #1 on: March 16, 2023, 06:14:28 AM
We use the pin #2 hot configuration for all of our XLR jacks, and I suspect the Purifi may be expecting the opposite.  You can reverse pins 2 and 3 on one end of each of your XLR cables or build a very short pair of adapter cables to make this swap available for you.
Reply #2 on: March 16, 2023, 06:35:34 AM
Reply #3 on: March 16, 2023, 07:53:10 AM
Man oh man, I have dropped the ball on getting the schematics into the BeePre2 output upgrade manual. Apologies, PB sent it to me months ago. I will get that incorporated.
Reply #4 on: March 16, 2023, 11:09:12 AM
I made a few corrections on these last week, so it's not the end of the world.
Offline denteom
Reply #5 on: March 17, 2023, 04:39:37 AM
I looked at the Manual of Purifi XLR configuration Pin 2 is positive on their configuration.  Do  I still switch the wire (Red and White) from Pin 2 to 3 and the resistor it from Pin3 to Pin 2? Does hot mean positive? Sorry not used to electronic terms.
Thanks for updating the manual, how do I download the updated version?
Reply #6 on: March 17, 2023, 09:23:11 AM
I would still try doing this outside the preamp if possible.  Here is another option:
https://vtvamplifier.com/product/pair-neutrik-rca-to-xlr-adapter/
Online Paul Joppa
Reply #7 on: March 17, 2023, 06:53:46 PM
I also checked the Purifi manual, and agree; I also looked at a block diagram to confirm it's a true differential circuit. In that case it should work fine with the BP2 XLR output. Reversing pins 2 and 3 should simply reverse the phase of the signal.
Which leads me to wonder if the problem is in the cable and/or the Purify XLR connection.
Offline denteom
Reply #8 on: March 18, 2023, 05:46:02 AM
Thanks for the inputs. I'll just build my own xlr cable to see if things will work out, and if still don't work I could flip the positive between 2 and 3 on the xlr cable if it won't work.
Question: Is cable length a problem on XLR? I have read XLR can have longer cables compared to RCA?
Doc B. hope I can also get a copy of the updated manual for the output upgrade,  I noticed some parts not clear to me but things worked out fine after looking at the photos.
Reply #9 on: March 18, 2023, 08:45:24 AM
I would also add that I occasionally use the balanced inputs on some ICEpower monoblocks from a BeePre with no issues.
Offline denteom
Reply #10 on: March 23, 2023, 05:26:06 AM
Thanks guys. You were right it was the xlr cable, maybe it was not making good contact.  I used a new Neutrik type xlr connectors, it plugged more snugly.
My previous xlr cable worked well with my solid state pre amp though. I'll keep that for microphone use.
My Beepre 2 functionality is now complete.
Doc B. When will the updated output upgrade manual be out for download? I'd also like to have a copy of that, as the copy I have does not have the schematics.
Offline PT
Reply #11 on: April 09, 2023, 06:38:49 AM
Where could we get the beepre2 output upgrade schematics? That would be nice to have
Reply #12 on: April 10, 2023, 11:14:47 AM
We're working on having the updated manual with schematics ready to go in the next couple of days. I'll let everyone know when we have it together, at which point current owers of the upgrade can email us for a download link to the updated manual.
Reply #13 on: April 11, 2023, 10:40:02 AM
The revised BeePre2 Output Upgrade manual with schematics is done. New orders should automatically get a link to download this revision. If you already have a BeePre2 output upgrade and would like the revised version of the manual with the schematics email us at [email protected] and we will send you a download link once we verify your purchase.
