Warm up time
denteom · 4718
Offline denteom
on: May 06, 2023, 03:23:05 AM
My Beepre 2 so far working fine, but noticed some quirks, Does the XLR need a longer warm up time before using it?  It sounded weird sound was softer on one speaker, kinda distorted on the other.  So I switched to the single ended and it sounded fine.  Then I decided hooking the XLR out to my headphone amp, so far sounding fine (I used it after a 25 minutes start up.
Haven't put XLR back to the power amps, but I suspect warm up time is needed.
What are your thoughts on this?
Reply #1 on: May 06, 2023, 12:05:40 PM
The warmup time is identical between the balanced and unbalanced output.  I would definitely take a look at the solder joints in that area if you have uneven performance between channels that doesn't exist from the unbalanaced outputs.
