No audio right ear [resolved]
Opal · 2677
Offline Opal
on: May 11, 2023, 03:52:38 PM
I just finish building my Crack and all the voltage test pass. Power it up and everything seem to works... untill i put my headphones on my head. No sound for my right ear.... I resolder the red RCA Jack made sure everything is welded and wired properly like 4 times. I did notice that the 12AU7 Tube did glow both half but one half was way dimmer thant the other side.
Here is the voltage test result
1 86.6
2 176.8
3 0.0
4 176.6
5 81.6
6 0.0
7 110.6
8 0.0
9 110.3
10 0.0
« Last Edit: May 12, 2023, 04:42:04 AM by Paul Birkeland »
Offline Opal
Reply #1 on: May 11, 2023, 03:58:16 PM
Here are some pictures of the build
Reply #2 on: May 11, 2023, 04:27:07 PM
The 12AU7 should be just fine since your DC voltages are correct.  Could you show the terminal side of the volume pot?
There are some 1/4 to 1/8" adapters that don't quite work properly in the Crack's headphone jack.  If you're using one, I'd try a different set of headphones to be sure it isn't something simple like that.
Offline Opal
Reply #3 on: May 11, 2023, 05:35:15 PM
You sir are awsome....that was the issue. Cheers to you and your love one. Now time to enjoy it :)
Reply #4 on: May 12, 2023, 04:41:56 AM
The fun thing is that the headphone jack is a Neutrik jack, and I've seen a Neutrik 1/4" to 1/8" adapter not work when plugged into it, go figure!
