Bottlehead Kits
Crack
no audio left ear after speedball instalation
Opal
5370
Opal
Jr. Member
May 18, 2023, 06:48:27 AM
I just install the speedball, and I do not have sound in the left ears, I did have sound in the left ear before the instalation. All voltage test on the small board pass but on the big board the voltage is higher
OA = 127
OB = 133
G = 0
B+ = 220
The LED are on
Paul Birkeland
Global Moderator
Hero Member
Re: no audio left ear after speedball instalation
Reply #1 on:
May 18, 2023, 09:07:06 AM
That is unlikely to cause one channel to not work. What are the small board voltages? Can you post some build photos?
Opal
Jr. Member
Reply #2 on:
May 18, 2023, 10:26:40 AM
Now some DEL are not turning on. Those DEL were turning bright red as soon as a plugged the power, while the other we slowly turning on. Now they do not.
Opal
Jr. Member
Reply #3 on:
May 18, 2023, 12:35:36 PM
small board voltage
OA = 87
IA = 204
B- A/B = 0
IB = 204
OB = 76
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
May 18, 2023, 02:38:25 PM
Your 2N2222 does not appear to be properly installed.
Opal
Jr. Member
Reply #5 on:
May 18, 2023, 04:07:44 PM
Did the fix, but no LED lights. I redid all the solder on the board. Still no LED lights.
Voltage still the same
Paul Birkeland
Global Moderator
Hero Member
Reply #6 on:
May 18, 2023, 04:11:36 PM
Can I see what the bottom of the big Speedball board looks like?
Opal
Jr. Member
Reply #7 on:
May 18, 2023, 04:17:43 PM
Here it is
Opal
Jr. Member
Reply #8 on:
May 18, 2023, 04:34:54 PM
Close up of the 2n2222 connection
Paul Birkeland
Global Moderator
Hero Member
Reply #9 on:
May 18, 2023, 04:48:39 PM
If you are using lead free solder, get some solder with lead. If you are using leaded solder, you need more heat to get solid solder joints.
Opal
Jr. Member
Reply #10 on:
May 19, 2023, 03:12:51 AM
I give up, I resolder everything for the 5th time and the LED are just not ligthing up. I m using solder with lead in it, and i did apply more heat, yet i still have the same issue
Opal
Jr. Member
Reply #11 on:
May 19, 2023, 03:15:13 AM
Here is the latest solder
Paul Birkeland
Global Moderator
Hero Member
Reply #12 on:
May 19, 2023, 04:12:58 AM
I would replace the 2N2222 that was improperly installed just to be safe, as it may not have survived its previous installation. Also be aware that the center legs of the TIP50 transistors take a lot of heat to solder properly.
Opal
Jr. Member
Reply #13 on:
May 19, 2023, 04:59:04 AM
It just keeps getting worse. Now one of the LED that was working before does not work anymore. I have not touched any soldering on that side.
Opal
Jr. Member
Reply #14 on:
May 20, 2023, 07:39:39 AM
Ok i talked to a professional and he did confirm that the 2N2222 was busted. I got a replacement but we cannot get it solder properly because I made a mess of the circuit board. Is it possible for me to order another one with some replacement pieces ?
Bottlehead Kits
Crack
