Testing with tubes terminal 7 read 1vdc instead of 170-230
DPetrini · 28372
Offline DPetrini
Reply #15 on: June 13, 2023, 07:18:25 PM
OA 13mV.  OB 8mV.   Before the final Reading the voltage fluttuante up to about 25mV
Daniel
Good hand at solder , badhead in electronics
Reply #16 on: June 14, 2023, 04:40:40 AM
What are IA and IB now?
Offline DPetrini
Reply #17 on: June 14, 2023, 06:34:11 AM
Both measure to iec ground are 468 vdc
No tubes in of course
« Last Edit: June 14, 2023, 07:33:48 AM by DPetrini »
Daniel
Reply #18 on: June 14, 2023, 09:32:13 AM
Something is very likely not well soldered on the PC board.  Can you take it out and show us the bottom side in better detail?
Offline DPetrini
Reply #19 on: June 14, 2023, 09:41:14 AM
Sure. See enclosed. What about if i get off all components ,clean It and reinstall new batch of 4 transistors? I have received them today from local supply
Daniel
Reply #20 on: June 14, 2023, 10:59:32 AM
Are you using lead free solder?
Offline DPetrini
Reply #21 on: June 14, 2023, 11:01:19 AM
I think its a very old kester. I finished It and Will now use weller Just arrived a couple of drops of the weller were used on this pcb i think when i reflow the soldering yesterday
« Last Edit: June 14, 2023, 11:03:37 AM by DPetrini »
Daniel
Reply #22 on: June 14, 2023, 11:04:21 AM
A very hot iron and low dwell time works well for the boards, but not enough heat will lead to flux building up between the solder joint and what it's supposed to solder, and you can end up with weird issues like this that don't make a ton of sense.  The exception is the LEDs, which have so little ability to dissipate heat that they solder very quickly.
Offline DPetrini
Reply #23 on: June 14, 2023, 11:08:14 AM
So what do you advise please?
Daniel
Reply #24 on: June 14, 2023, 02:27:13 PM
I would reflow every joint on that PC board other than the LEDs.  What you have is not consistent with a transistor failure.
Offline DPetrini
Reply #25 on: June 14, 2023, 11:50:22 PM
I am cooked as well. Reflow all,still not working. What if i dismantle It almost completely and start from scratch? Will you accept order for a list of components or out of your scope and should buy them locally?thanxs and apologize for not being a good fellow that makes things right First Time.
Daniel
Reply #26 on: June 15, 2023, 04:41:19 AM
You can contact replacementparts(at)bottlehead(dot)com about getting a replacement PCB and parts for your Stereomour.  Some 60/40 leaded solder and a soldering iron set to 800+F would probably help too. The old Kester should work well provided it's leaded (not silver bearing).
Offline DPetrini
Reply #27 on: June 15, 2023, 07:48:04 AM
Thanxs! The solder station Is decent at 65w. Ordered now 60/40 Classic lead no silver. I want to make It working this time. Will check continuity or resistance at each soldering parte. Sent mail to your ref mail to ask offer quote. Cheers
« Last Edit: June 15, 2023, 10:51:01 AM by DPetrini »
Daniel
Offline DPetrini
Reply #28 on: June 19, 2023, 09:53:06 AM
Dont think Will finish this amp. From thursday last week ,when i wrote for replacement parts,nobody took care of me.  Not what i expected, honestly
Daniel
Reply #29 on: June 19, 2023, 03:15:33 PM
I will have Eileen check in the spam folder.  Our e-mail service isn't always the best at proper filtering.
