Power cord for Australian 240VAC (10A wall sockets)
oztayls · 11521
Offline oztayls
  • Still waiting for proof of the THING...
I'd like to make some cords for my gear. I can get some nice hospital grade Australian plugs and some straight and angled IEC connectors that are lockable with a plastic insert to prevent them coming out.
Also, I'm just checking that the wire needed is the stranded type, not solid core?
From my local electronics store, I can get 19AWG 7.5A wire or 17AWG 10A wire. Because we twist them in pairs, I'm thinking the smaller 19AWG 7.5A wire will be preferable or else I might run into trouble fitting them into the connectors? I think this would still result in a 7.5A rated cord would it not, as the individual twisted wires are rated at 7.5A?
Thorens TD124, TD125, ARXA, ARXB, Stereomour II (no mods), Spud Kit amp 2.3wpc, Boyuu A50 Mk3 300B 7wpc, EAR 834P, Leak Sandwich 15ohm, Leak Mini Sandwich 15ohm, Lii Audio Fast-8 OBs, Klipsch Heresy 1.5s, On the Decware 4-year wait list for SE84UFO2.1
Reply #1 on: July 30, 2023, 06:23:37 PM
You probably want to use stranded wire for a power cable, solid could be unwieldy and possibly prone to failure if it gets moved around.
 Even a single run of the 17 or 19 AWG will be more than  sufficient for your  current needs, Just use a configuration that makes you happy....John
Reply #2 on: July 31, 2023, 04:23:09 AM
Double 19 is going to be plenty on 230V mains.
Offline oztayls
Reply #3 on: August 02, 2023, 03:31:07 PM
Thanks guys  ;)
