Failed voltage check, some LEDs not lighting up, tube no longer lighting up
Shackney1127 · 15535
It is possible that a wire has been nicked when the insulation was stripped and the nick turn into a break as the wire was worked. These will sometimes be under the insulation where they can't be seen and often cause intermittent behavior.
I would send this in for repair. You can contact queen(at)bottlehead(dot)com and let her know that we have been working on this on the forum and I let you know you could send your kit in for repairs.
