I’ve been running an ~18 year old power amp with 6AV5GA power tubes, and decided it was finally time for an upgrade. When I built my Moreplay to feed this old amp, it improved the sound markedly, even tho the old amp had recently been gone thru with all time-suspect hardware replaced by the manufacturer. Most recently I’ve been into the tube sound, but occasionally miss the whomp of a Dynaco 400 I put together once upon a time when dinosaurs roamed the earth. Hmmm. So I looked around in my price range and decided to go with an NAD C298. I found that there is at least one manufacturer thats making a hybrid power amp with tubes up front, and solid state for power. So I decided to mimic this setup with seperates. Moreplay pre, NAD power amp for….power. I was a little hesitant as I’m unfamiliar with Class D power amps though they seem to be showing up more and more.
I am thrilled with the combo.
Nonetheless I’d like to hear from anyone else currently using this approach, or from anyone that cares to address the pro’s, con’s, etc.
The only major downside I can see is simply keeping my Moreplay in vintage 6V6’s as they seem to be in demand. I’ve ponied up for several pair which should keep me going awhile.
“First you fly, then you die!â€â€”Los Lobos
Mac mini->Denafrips Ares II dac->Moreplay pre->NAD C298 power amp->KLH 5 (2023) speakers.
Mac mini->Denafrips Ares II dac->Crack/Speedball amp>Sennheiser HD600 headphones
