Bottlehead Kits
Eros Phono
Failed Resistance Test
Toys4Boys
18783
Toys4Boys
Full Member
October 08, 2023, 03:42:18 AM
I'm praying that I didn't cook several resistors when soldering, measuring open circuit at input/output center pins.
Paul Birkeland
Global Moderator
Hero Member
Re: Failed Resistance Test
Reply #1 on:
October 08, 2023, 05:48:55 AM
Can you post some build photos? What meter are you using?
Toys4Boys
Full Member
Reply #2 on:
October 08, 2023, 06:40:39 AM
The meter is a generic Amazon Auto Ranging Meter, Assark. I am getting an open circuit when I test the ends of the aforementioned resistors, other 90 ohms seem to measure in range.
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
October 08, 2023, 06:41:19 AM
Can you send a link to the meter?
Toys4Boys
Full Member
Reply #4 on:
October 08, 2023, 06:42:35 AM
https://www.amazon.com/dp/B09F2MLTR9?psc=1&ref=ppx_yo2ov_dt_b_product_details
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
October 08, 2023, 06:56:13 AM
That should be able to measure the 47K resistors across the input RCA jacks. What comes up on the screen when you try? Do you have the 620A or 85D?
Toys4Boys
Full Member
Reply #6 on:
October 08, 2023, 07:00:36 AM
85D, no reading, just seats at 0L.
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
October 08, 2023, 07:28:20 AM
If you're in the US, I would go buy the ~$25 meter at Harbor Freight, then try again. You would be the first customer we've ever had that burned up all their resistors, so my money would be on the $9 meter at Amazon just being a bit of POS.
Toys4Boys
Full Member
Reply #8 on:
October 08, 2023, 07:31:42 AM
I'ld prefer to believe that as I thought that I used proper care in my build! Okay, I'll get the HF meter.
Paul
Toys4Boys
Full Member
Reply #9 on:
October 08, 2023, 08:39:54 AM
I'm seeing a $20 then a $45 meter at HF, is there value for the hobbyist to get the more expensive model?
AG
Full Member
Reply #10 on:
October 08, 2023, 08:49:09 AM
https://www.ebay.com/itm/235244060542?epid=1400247856&hash=item36c5a37f7e:g:gLYAAOSw~mVlIEoh&amdata=enc%3AAQAIAAAA0J20nNKMRBNFuIEzF6LxwrB%2BAP2uXOHDIkBI%2BHLQflIJzq6QVwPzCjglhH3ubsQSizcGX%2ByKtwGgpk4QLBw1EWrHW60ebvfoJRfFdRWJ9qfcfKvSKqmB9LvVXkNS%2F6yzg8ChtGB9ZJVVae2bO9QEwqtJW8tplATpLkhDug6wsBJuDW6jM7DrC%2BgjSLjPhThKJW1Vy7Oy1u7U70L7JuspFuWUQVPwWBDiO3HfIOxI6PsCWM8jBnFAxJZDmXVMWie4JL%2BAabEDulocJdVlkUIBFq8%3D%7Ctkp%3ABk9SR6Dx8oniYg
not bad.
AG.
“Without music life would be a mistakeâ€
Toys4Boys
Full Member
Reply #11 on:
October 08, 2023, 08:51:57 AM
Yeah, if I get lucky! Nice find though. I looked at the reviews on the HF meters and whie there were considerably fewer for the $20 model they were overall far better than the $45 model.
Toys4Boys
Full Member
Reply #12 on:
October 08, 2023, 08:54:47 AM
Threw out a bid, might just wait till tomorrow before buying the HF model, although I am champing at the bit to get my Eros up and running
Paul Birkeland
Global Moderator
Hero Member
Reply #13 on:
October 08, 2023, 09:27:03 AM
https://www.harborfreight.com/9-function-digital-multimeter-with-audible-continuity-59410.html
You'll need to adjust the resistance ranges to something sensible for whatever you're trying to measure, but this meter should work well for you. The probes kind of suck though, so down the road I would also suggest some inexpensive silicone meter probes too.
Toys4Boys
Full Member
Reply #14 on:
October 08, 2023, 09:29:22 AM
Thanks Paul, just waiting to see if the Patriots get scored on again
before heading out for that.
Bottlehead Kits
Eros Phono
