Volume pots
jrihs · 18692
Offline deltaunit
Reply #15 on: March 31, 2011, 06:41:44 AM
Thanks for the replies, I think I might be able to swing an Alps Blue through work so may go for that. Excellent looking build STURMJ. Cheers
Offline jrihs
Reply #16 on: April 04, 2011, 06:33:52 PM
ARRRGHH......Can't make up my mind between the TKD-70897 and DACT at twice the price! I'm sure there is a difference. Just not sure I would hear it. ONE thing could help me decide....which one does not require modifying the hole-in-the-plate? if either or neither. Any strong opinions on either Pots?
Thanks!!
John Rihs
Reply #17 on: April 04, 2011, 06:50:10 PM
FWIW I prefer Goldpoints over the DACTs.
Offline jrihs
Reply #18 on: April 04, 2011, 07:02:31 PM
OK! I was just reading about those and others seem to prefer it as well. Are you referring to the standard or custom goldpoint? Does it require a bigger hole? What sonic qualities do you like about it? More transparent?
And THANKS!!
John Rihs
Offline Beefy
Reply #19 on: April 05, 2011, 02:49:26 AM
Simple question...... how confident are you that you can find your perfect listening level on a 24 step attenuator? Especially given that the DACT is 4dB or greater steps up to -34dB - I don't even get close to that high a volume with my Crack/Speedball/5998.
Offline pro_crip
Reply #20 on: April 05, 2011, 03:56:53 AM
I made the custom goldpoint using their list and dale rn60 resistors. If your soldering skills are up for it, you can use surface mount. From what I recall, it was a straightforward build. You start at r1 and work your way all the way over to r24. The build takes some time, but that just gives you more fumes to huff ;P Thanks for listening.
Rich
Richard J Feldman
Tune down, smoke up
Offline jrihs
Reply #21 on: April 05, 2011, 04:03:54 AM
So I take it the custom goldpoint would fit then?
John Rihs
Offline jrihs
Reply #22 on: April 05, 2011, 07:15:21 AM
Well, I guess all my questions are moot since I just ordered the goldpoint standard!
Cheers!!!
John Rihs
