Adding more inputs to the Quickie
royewest · 16403
Offline royewest
on: October 13, 2023, 09:23:59 PM
Work has finally slowed down enough that I'm coming back to this project (from earlier this year -- not when I got the kit ; )
How hard would it be to add one or two more line ins?
I think the 1.0 I built had a simple switch with 2 pairs of 3 connectors (2 channels x input 1, gnd, input 2). I could imagine such a switch with more inputs (if such a thing exists), But the rotary switch in 1.1 frankly mystifies me.
Is this a simple mod? Or am I asking for trouble again?
Thanks you,
__Roy
Reply #1 on: October 14, 2023, 05:45:37 AM
You could certainly take the toggle switch out of a 1.0 and put a rotary switch in to get more inputs.  You'll also need to drill more holes in the acrylic for extra RCA jacks.  Drilling acrylic can be a bit obnoxious though, so it may be worth it to start fresh on a piece of aluminum instead.
Offline royewest
Reply #2 on: October 14, 2023, 01:43:54 PM
Thank you, Paul.
I have a 1.1 kit with the rotary switch. Can that rotary switch be used to add a third input, instead of 0, and add a separate power switch (that even I can figure out...)?
__Roy
Reply #3 on: October 14, 2023, 02:45:37 PM
The rotary switch in the 1.1 does both input selection and filament power.  You'd lose your power off position if you tried to add a third input.
Offline royewest
Reply #4 on: October 14, 2023, 04:59:49 PM
Got it. 2 inputs is really nice. Thanks again for the guidance, Paul
