Blown mje350 and led [REPAIR VID AT END] [resolved]
Rob C · 172828
Reply #30 on: November 14, 2023, 05:23:06 AM
Yes , the 375 volt will be more reliable. The higher voltage is the primary reason for changing from the MJE350.
If there were an even higher-voltage PNP transistor available, I would probably want to switch again.
Reply #31 on: November 14, 2023, 05:34:21 AM
Either one will work adequately in the Paramount.   The change is to buy a little extra tolerance to high voltage (the MJE350 is rated for 300V max) and to better handle the thermal requirements in that position.
Offline Rob C
Reply #32 on: November 24, 2023, 06:07:43 PM
https://youtu.be/0LyUAwK985c?si=dsYMtSWcko1YbfEU
SUCCESS!  YOU GUYS ARE GREAT! THANK YOU!
4 out of 5 diodes fried.
« Last Edit: November 24, 2023, 06:45:26 PM by Rob Capizzi »
Reply #33 on: November 25, 2023, 06:10:20 AM
The presence of the MJE350 in the original circuit was likely the cause of the fried zener diodes.
Don't hesitate to clip a little heatsink onto the 5731A down the road if you can.
Offline Rob C
Reply #34 on: November 25, 2023, 06:14:18 AM
I will. I have mini ones that'll be perfect.  All of them I suppose could benefit, even the power supply board? What's the best way to attach? Thermal paste and maybe thin tie wire twisted.
« Last Edit: November 25, 2023, 06:27:43 AM by Rob Capizzi »
Offline Rob C
Reply #35 on: November 25, 2023, 06:57:13 AM
I'm going to pick up heatsink glue
Reply #36 on: November 25, 2023, 07:48:45 AM
I would just get some small clip on heatsinks for TO-220s.  I wouldn't glue anything on or use thermal grease, that's pretty overkill for the application.
Offline Rob C
Reply #37 on: November 25, 2023, 08:14:57 AM
I got nte425. Thermal Interface pad self adhesive.
Reply #38 on: November 25, 2023, 08:35:29 AM
Something like this is fine:
https://www.digikey.com/en/products/detail/assmann-wsw-components/V8508A/3476148
If you need to take the heatsink off for future work, it's pretty easily done.
Offline Rob C
Reply #39 on: November 25, 2023, 11:01:29 AM
Do any of the repairs I've done have an effect on the audio at all? Sonics, volume?
Reply #40 on: November 25, 2023, 05:06:56 PM
No, you're just replacing broken parts with new ones.
Offline Rob C
Reply #41 on: November 26, 2023, 03:48:18 AM
Heat sinks
Offline Rob C
Reply #42 on: November 30, 2023, 05:37:45 AM
Should I replace all four mje350 on both boards in both amps?
Reply #43 on: November 30, 2023, 05:47:04 AM
I would take the heatsinks off the high voltage rectifier diodes, as they dissipate nearly no heat. Likewise on the remaining MJE350 in the Paramount.
Offline Rob C
Reply #44 on: November 30, 2023, 06:03:45 AM
Ok I will. I am also going to replace the old A side mje with mje5731AG on both amps. Also both on the center board in the foreplay. I will only heatsink the MJE5731ag  on the B side only? . I assuming the MJE5731ag  will work on both the A and B side. Any other prevention upgrades I should do?
Also, why in the manual ,A side calls for MJE5731a and B side mje350?  Thanks.
« Last Edit: November 30, 2023, 06:25:50 AM by Rob Capizzi »
