Is using RCA short plugs on inputs safe?
ipetruk · 1909
Offline ipetruk
  • Igor Petruk
on: November 23, 2023, 10:02:49 AM
It should be, I think, but I want to double-check.
I'd like to do it for aesthetic reasons mostly. In theory it should reduce noise if inputs cross-talk and some are unused, but they don't really do that in my case. I have Crack and Mainline. I've modded Crack by embedding the DAC, but it still has unused original input RCAs behind a switch.
Also, in case you know, is it safe to use those on COAX inputs in DACs, also mostly for aesthetics.
Crack, Mainline, Pipettes, Subette
Reply #1 on: November 23, 2023, 10:11:39 AM
None of our products are bothered by shorting plugs on the inputs.
