Advice needed. Terminal 46 over limit for resistance check.
CuriousMister · 22050
Offline CuriousMister
Reply #15 on: December 20, 2023, 03:15:14 PM
You’re right about the 130ohm resistors.  Only one could be read while attached - the only good one.  3 are toast.  Based on what’s online, does it matter what wattage rating I replace them with?  This may have been my problem from the beginning.  I’ll replace them and report back when installed.
I really do appreciate your advice.
Reply #16 on: December 21, 2023, 05:36:52 AM
That issue will happen either from the 2A3 insertion as I mentioned, or from backwards 100uF/450V caps, which act like a short when installed backwards and destroy the 130 ohm resistors.
If you use 1/2W resistors, they will probably last a few days/maybe a week.  A 1W resistor around a year or two maybe, and a 2W resistor indefinitely (other than failure from fault conditions of course).
Reply #17 on: December 28, 2023, 03:30:14 PM
Another request for advice after installing three new 130ohm resistors.  The good news, my initial problem is fixed.  I think.  A new one sprung up though.  At both terminals 4 and 17 I get fluctuating DC readings (trending up over time).  Measurements ranged from 8 to low 30s after a second reading.  29 is also not zero.  It is -1.  Do you have any ideas or thoughts?
Once again, thank you for helping me get this one over the finish line!
Tom
Reply #18 on: December 30, 2023, 06:15:12 AM
What are the units on this reading?  Is that 8 to 30 mV, 8 to 30V, etc?
29 connects to all sorts of terminals via the buss of black ground wires.  If it doesn't measure exactly the same as any of the terminals its wired to, then there's a bad solder joint along that string of black wires.
Reply #19 on: December 30, 2023, 12:04:57 PM
The readings at 4 and 17 were both in mV.  I’ll do some joint management on the black wires connected to 29 like you suggested later tonight.
Reply #20 on: December 30, 2023, 01:04:48 PM
0.004-0.017V is close enough to 0V to not worry about in that spot.
Reply #21 on: December 30, 2023, 03:26:49 PM
I think we are golden! I measured all the terminals connected to 29 by black wires. They are all effectively the same - between 0.7-1mV. Would you say I’m ready to move on to the hum test now?  SO thankful for your trouble shooting.
Reply #22 on: December 31, 2023, 06:24:06 AM
Sure, that seems reasonable.
