General Category
General Discussion
Eight Ohm Amplifier on Four Ohm Speakers
Cary
109
Cary
Full Member
April 06, 2024, 06:52:38 AM
My Bottlehead amplifiers are wired for eight ohms, if I connect four ohms speakers with them would there be any difference in sound quality if my amps were wired for four ohms?
Doc B.
Administrator
Hero Member
Re: Eight Ohm Amplifier on Four Ohm Speakers
Reply #1 on:
April 06, 2024, 07:05:21 AM
Distortion will be a little lower using the 4 ohm output and bass is often a little tighter than it would be using the 8 ohm output on 4 ohm speakers. It depends a lot on the speaker used. You can try both ways and see what you like without causing any issues.
Cary
Full Member
Reply #2 on:
April 06, 2024, 07:31:08 AM
Thanks Dan! Wishing you and Eileen our bests.
General Category
General Discussion
