Mechanical Buzz from Power Transformer on BeePre2
BrucePoi · 30837
Offline BrucePoi
on: April 09, 2024, 07:50:39 AM
Hello,
I've had a mechanical buzz coming from the power transformer since I built my BeePre2, and I've finally started troubleshooting it.  My unit has all of the upgrades but no part substitutions or modifications.  Here's what I've done so far:
- read through the forum thoroughly, first.
- checked incoming AC voltage as someone had an undervoltage condition around ~114VAC which caused a buzz.  From the wall I'm getting 121.4VAC.
- verified the correct sequence of star/lock washers and plastic/fiber washers/inserts in relation to the screw, end cap, transformer, chassis plate, nut, standoff, etc.
- cranked the hardware to within an inch of its life using an 11/32" wrench on the nuts.  No change.
- the latest attempt was installing nitrile o-rings as soft mounts, both underneath the end cap and between the transformer and chassis plate.  No change.
- tried re-torquing the hardware at different levels after the o-rings.  No change.
Still, the problem persists.  It's a mechanical buzz at 120Hz.  It does not come through the speakers, and in fact you can hear the buzzing with the preamp on but the amp (Kaiju) off.  It's not obnoxious, but once you hear it you can't un-hear it.  It's audible at the listening position ~9-10' away with no music on if you listen for it.
The other thing to note is that with the power turned on but the tubes removed on my test bench, there's no buzz.  The buzz only starts when there's a load on the secondary.
Does anyone have anything else I might try?  I can take pictures if they'd be useful.
Bruce
Reply #1 on: April 09, 2024, 08:47:37 AM
We got a batch of transformers in which a few were a little noisy, in the early days of BeePre2. Did you buy your BeePre2 kit a few years ago?
Offline BrucePoi
Reply #2 on: April 09, 2024, 10:54:49 AM
Looks like I purchased it on 5/25/2023.
Reply #3 on: April 09, 2024, 06:03:16 PM
If you rest your hand on the metal cover of the power transformer, does the noise diminish?
Offline BrucePoi
Reply #4 on: April 10, 2024, 09:41:35 AM
Paul,
I just did some testing.  If I rest my hand on the end cap, the noise does not go away.  I tried a light touch, heavy handed, etc.  I left it on for 10 minutes to warm up to see if that made a difference, but no change.  Also, I didn't notice any vibration on the end cap, transformer, or chassis.
With the nitrile o-rings as soft mounts, I have a ~0.110" +/- 0.010" gap between the flange of the end cap and the laminations on the core itself.  I found if I can wrap my fingers and palms to close that gap, the noise goes away completely.  As soon as a little gap opens up in my "seal" though, the buzz comes through.  This makes me wonder about removing the soft mounts, but I was getting the buzz in the standard configuration too.
Let me know if you have something else I can try.
Bruce
Reply #5 on: April 11, 2024, 06:45:15 AM
On some different transformers I've been using from a different vendor, I've been struggling a bit with the transformer cover rattling against the bits of the transformer under it.  For your Kaiju, it might just be that the varnish underneath is in just the right spot that the top cover can rattle against it, or it could be that bits of the bobbin are sticking up just enough to contact the top cover.
One experiment you could try is just running the amp without the top transformer cover (definitely put the screws back though) just to see if that offers any kind of relief.  If so, maybe post a picture of what the top of your PT looks like and maybe it's just a matter of cutting some of the plastic away or adding some goop under the cover to keep it stationary.
Offline BrucePoi
Reply #6 on: April 14, 2024, 07:31:41 AM
Paul,
The transformer cover wasn't contacting the transformer itself on my BeePre2 because I had already tried inserting nitrile o-rings as some sort of soft mount between the two on the screws.
I took the end cap off and remounted the transformer, but I'm still getting a buzz directly out of the transformer.  The short video below has a clip of me switching the preamp on without tubes--and it's dead silent.  The next clip in the same video shows me turning it on, with tubes in, and you can hear the buzz.  I'm also showing you my line voltage.  I used the 115-130V option when wiring.
How do I quantify how loud it is, given it's a cell phone video.  Well, my Kaiju's power transformer really is dead silent, even with tubes in and my ear right up to it.  It's louder than the buzz from 1971 Fender Twin Reverb in standby.  At my listening position 9' away, you can hear it--especially if you know what to listen for.  As I said in my first post, once you hear it you can't un-hear it.
Let me know if you have some other things I could try.
Bruce
https://youtube.com/shorts/m824NZHDAic?si=BqbWcAeil9nehqa-
Reply #7 on: April 15, 2024, 05:55:00 AM
I think it's worth giving a replacement transformer a shot.  I believe we will be getting a fresh batch in this month.
Offline BrucePoi
Reply #8 on: April 23, 2024, 07:04:00 AM
If you can confirm the correct address to ship it, I'll get the old transformer returned ASAP.
Bruce
Reply #9 on: April 24, 2024, 12:27:20 PM
26272 12 Trees Lane NW
Suite D
Poulsbo, WA 98370
Offline Green0
Reply #10 on: May 29, 2024, 10:05:47 PM
Hi Bruce,
I am interested in if you had success with the replacement transformer? I have a Beepre2 running in my system purchased in September of last year and have experienced a very similar mechanical buzz to what you shared in your video. My Beepre2 is also stock with all upgrades.
Best,
Aaron
Reply #11 on: May 30, 2024, 05:49:02 AM
I think it's worth mentioning here that some transformer noise isn't particularly abnormal.  I have gotten back a few PT-9 power transformers that were returned for noise issues and I can only hear noise if I'm very close to the transformer (so those transformers are currently running in my system).  We did have our winder revise the transformer design a while back to remedy an issue where there would be a loud buzzing audible from 6+ feet away, but so far that issue seems to be resolved.  Do also note that loose hardware on the power transformer can amplify an issue like this as well.
Offline Felice
Reply #12 on: July 22, 2024, 06:22:37 PM
Hello
Your last answer is not very encouraging.
I have the Bee Pre1
It was modified so that the transformers have no influence on the sensitive 300b. Taica gel washers work wonders.
But the channel separation of the BeePre1 could be better.
No matter, I would like to build the Beee Pre 2. After all, a lot of time has passed and it's time for something new.
But when I read that the mains transformer has a mechanical hum, I feel sorry. I hate nothing more than transformers like that. First of all, the Beee Pre would be standing almost a meter in front of my nose and making a mechanical noise, which is unacceptable.
Then I don't understand why it is not possible to build absolutely quiet mains transformers. That worked perfectly decades ago with E-shaped transformers. After all, other manufacturers can do it too.
Otherwise, you can encapsulate a transformer.
As long as the problem is not 100% solved, I will wait.
