Did I fry my PT-10??
[email protected] · 6124
Offline [email protected]
on: June 15, 2024, 08:01:02 PM
Regarding my 120v new crack build:  did I fry my transformer if I powered the unit on while mistakenly connecting 14U to 21U instead of 20u (ref: Top of page 40 of the Crack manual)? Voltage checks result in mostly zeroes, although both tubes are glowing. LEDs do not light up.
Thx in advance y'all 😁
« Last Edit: June 15, 2024, 08:10:53 PM by [email protected] »
Reply #1 on: June 16, 2024, 06:09:57 AM
No, that shouldn't have any impact on the power transformer, but you won't develop any DC voltage for the circuit to run.
Reply #2 on: July 22, 2024, 01:41:21 PM
Thanks for your quick response Paul! I'm not so speedy lol.
After fixing my mistake (black wire connecting 14u-20u) and triple checking all other connections and polarities, I'm still not generating much in the way of DC voltage.
FYI, all resistance checks are confirmed. I retested earlier power tests to confirm the following:
    P.23 voltage test = 121.5v
    P.29 pt secondary tests = 6.45v and 171v
    P 31 glow check passes
Now for the bad...
P.49 DC voltage checks
      T1= .95v
      T2= .95v
      T3= 0
      T4= .95v
      T5= .95v
      T6= 0
      T7= 4.8v
      T8= 0
      T9= 3.3v
      T10= 0
The above leads me to believe that I fried and need to replace my pt-10. However, if you've got reason for hope, I'm all ears!!
Thanks again...Todd
Reply #3 on: July 22, 2024, 02:03:14 PM
How is your PT-10 fried if it's putting out the correct voltages?
Can you post another build photo?
