Just completd my Crack build. Question about voltages [resolved]
atom631 · 25911
Offline atom631
Reply #15 on: July 08, 2024, 07:49:02 AM
Terminals 2 and 4 should be identical.  If you double check and see a half a volt drop between the two, I'd reflow the solder joints on the jumper wire that connects them together.
so i was using the amp for a bit. then saw your message. unplugged and waited about 10-15 minutes. re-tested. terminal 2 and 4 were now identical. but they only were showing 164.8v.
disregard last comment. i tried again and got a better bite on the 12u terminal with the alligator clip and they are both now showing 170 on the nose.
« Last Edit: July 08, 2024, 07:54:51 AM by atom631 »
Nice looking build, both outside and in. Enjoy.
