Just completd my Crack build. Question about voltages [resolved]
atom631 · 25910
Offline atom631
I just finished my Crack build. I wanted to post some pics, but it says Im not allowed to post external linkes.
Anyway, I passed all the resistance checks. When I tested the voltage, I had 3 outliers... Terminal 2 and 4 were both 211 volts and supposed to be 170. Terminal 7 is supposed to be between 90-115 and I was reading 118v.
I know on the next page it says tube tolerances can vary the voltage and to not worry about it, but i just wanted to double check.
Also -  what is the break-in or burn in procedure for the Crack?
Thanks!!
« Last Edit: July 08, 2024, 08:30:40 AM by Paul Birkeland »
Reply #1 on: July 05, 2024, 06:26:27 PM
What is your incoming powerline voltage?  You can upload photos directly to this forum.
Offline atom631
Reply #2 on: July 05, 2024, 06:57:53 PM
Im the States, so 120v. I think thats what youre asking.  :-[
Reply #3 on: July 06, 2024, 09:02:07 AM
No, I mean what did you measure out of the wall?  Also can you post a build photo?
Offline atom631
Reply #4 on: July 06, 2024, 11:40:41 AM
Ill have to remeasure.
here are pics of my build:
Offline atom631
Reply #5 on: July 06, 2024, 12:42:45 PM
I just retook the measurements. I had it off and unplugged for about 45 minutes before I tested:
Terminal 1: 83.7
Terminal 2: 208.5
Terminal 3: .3
Terminal 4: 208.6
Terminal 5: 80
Terminal 6 .1
Terminal 7: 116.3
Terminal 8: .4
Terminal 9: 110.7
Terminal 10: .1
Reply #6 on: July 07, 2024, 05:39:37 AM
I'm asking what the voltage is that you measured during the test on page 22 of the manual.
Offline atom631
Reply #7 on: July 07, 2024, 09:02:48 AM
ah. sorry, im totally new at this. I dont recall the exact reading, but it was under 115, so I followed the directions there.
is it possible to re do the test with everything soldered up?
Reply #8 on: July 07, 2024, 10:57:34 AM
I think you need to recheck this.
Yes, or you can set your meter to AC volts and just measure a wall outlet in your home on its own.
Offline atom631
Reply #9 on: July 08, 2024, 04:41:44 AM
I think you need to recheck this.  Yes, or you can set your meter to AC volts and just measure a wall outlet in your home on its own.
So, this is probably the issue. When I test an AC outlet or reperform the test on page 22, Im getting 123.7v.
Not sure how I messed that up originally. Looks like I need to swing the red wire from N (on IEC) to 14 on transformer over to 15 on transformer. Then move the red jumper over thats on 14 to 17 to 15 to 18.
Reply #10 on: July 08, 2024, 05:17:39 AM
Yes, you have the power transformer wired for less than 115V and it needs to be wired for the next range up.  That will drop your DC voltages down a bit and you'll find that things look a lot better once that's done.
Offline atom631
Reply #11 on: July 08, 2024, 05:31:29 AM
thanks!!
for my own curiosity- lets say this wasn't caught and i went about using the amp. what wouldve happened? im assuming its pushing more voltage than needed to the tubes thus making them run hotter and wear out prematurely? would there be any change in sound?
Reply #12 on: July 08, 2024, 06:05:34 AM
You probably are out of spec on the the 6.3V heater winding, and that is not great for tube life.  The start up DC voltage before the tubes conduct is probably a little higher than the 250V rated caps would like to see.
Offline atom631
Reply #13 on: July 08, 2024, 06:40:01 AM
got it. thanks.
Made the changes and here are the new results. Looks like Im all good:
Terminal 1: 77.6
Terminal 2: 170.4
Terminal 3: 0
Terminal 4: 169.9
Terminal 5: 74.7
Terminal 6 0
Terminal 7: 99.6
Terminal 8: 0
Terminal 9: 95.5
Terminal 10: 0
Reply #14 on: July 08, 2024, 07:06:32 AM
Terminals 2 and 4 should be identical.  If you double check and see a half a volt drop between the two, I'd reflow the solder joints on the jumper wire that connects them together.
