Wire Insulation Question?
pbvoorhees · 1446
Offline pbvoorhees
on: December 10, 2024, 06:05:40 AM
Greetings everyone,
I am in the middle of wiring my S.E.X. kit. And it is my first build.
So far, so good.
However, last night as was soldering the H2L-H7L spots near the power transformer, the iron was close very to the red wire that connects to terminal 7 on the PT-10  (see page 36 in 3.0 manual). While there is no gaping spot of exposed wire, the insulation above H3L and H6L does not feel smooth. I can't visibly see silver wire with my naked eye (because it the area of concern is facing the top plate), but maybe there is a splinter-sized exposure of silver wire around one (or both) of these spots.
My question is: Do I need to be concerned about the red wire (that connects to terminal 7 on the PT-10)? Or am I being overly cautious here?
I am having a great time learning as I build this kit but don't want to go further if I may have compromised something.
Thanks in advance for any and all feedback.
Pieter
Reply #1 on: December 10, 2024, 06:15:42 AM
As long as any exposed bit of wire can't touch any other metal it's not an issue. You could always detach it, and slip a small length of heat shrink tubing over it and reattach if you feel it needs to be covered. From your description I doubt this is necessary.
