Bottlehead Kits
Eros Phono
Done!
Done!
Ivan303
16282
Doc B.
Administrator
Hero Member
Re: Done!
Reply #15 on:
April 14, 2025, 01:07:48 PM
That output cap is currently a 1.5uF at 630VDC. I don't recall if it was spec'd 1uF at 400VDC in the past, but it may have been. That cap won't see much more than 275VDC so either 1.0uF at 400VDC or 1.5uF at 630VDC is fine.
Paul Birkeland
Global Moderator
Hero Member
Re: Done!
Reply #16 on:
April 14, 2025, 01:55:45 PM
It's listed as a 1.5uF in the manual, though it has gone back and forth from 1uF to 1.5uF over the years depending on what's in the inventory. There is a good amount of flexibility for this value in the Eros.
Brooklynvalve
Newbie
Re: Done!
Reply #17 on:
April 15, 2025, 05:19:08 AM
Got it. Thanks much for the clarification.
hmbscott
Full Member
Re: Done!
Reply #18 on:
April 15, 2025, 08:00:04 AM
I recently switched from using an Audyn MKP Plus 1.50mF 800Vdc to an Audyn True Copper Cap 1.0uF 630V output cap. There was no adverse impact on sound quality. Quite the contrary actually.
Scott
[U-Turn Theory > Hana ML > Eros IIw/Sowter 1490 SUT] & [iMac M1 Apple Music lossless/hi res > HQPlayer > Denafrips Ares II] >> Moreplay >> Stereomour II >> Hsu ULS-15 Sub & DIY DML Speakers
Bottlehead Kits
Eros Phono
Done!
