A few questions before buying BeePre2
bond007 · 2221
Offline bond007
on: March 04, 2025, 11:47:20 PM
Hi,
I have several questions before buying the BeePre2:
1) Is it fine for 230V mains or have to be converted / used with a 120/230V transformer?
2) Balanced input / output is an option. There is a kit for output, but input has to be done without a kit. Correct?
3) Any chance the BeePre2 can have a switch to toggle from stereo to mono?
Many thanks
Alex
Reply #1 on: March 05, 2025, 04:28:19 AM
Hi,
It has a universal power transformer that can be wired for 230V
That is correct
That is something you would have to add on your own. Are you trying to blend the left and right stereo channels in the preamp, or are you trying to get a mono source to feed both channels? Depending on how you want to do this it could be as simple as a switch that combines the left and right input signals. If you want to do it at the output it gets more complex. If you only need a mono setup occasionally you could just use a y-splitter adapter on either your input or output interconnect cables.
Reply #2 on: March 05, 2025, 04:44:54 AM
I can see it being quite easy to sum both channels at the output of the stock circuit, though I think this would work a lot better with both upgrades installed.
Balanced inputs require a 15k:15k input transformer with a threaded bushing mount, which are a special order item that takes a little bit of time to order.  Beyond that, the installation is pretty simple.
