BeePre 2 fuse spec?
300bees · 1953
Offline 300bees
on: April 02, 2025, 03:30:42 PM
Hello!
First off, deep thanks and kudos to my father @yossihaimberg for building me the BeePre 2 with upgrades. I enjoyed many hours of music already in the short time I have had it here. Thank you to the Bottlehead team for coming up with this exceptional design.
My pre has been blowing fuses occasionally. I have not narrowed down the exact conditions that cause fuses to fail. The fuses never blow while the pre is on.
As a first step, I'd like to verify I am using the correct fuses: 5mm x 20mm 1A? Slow or fast?
Appreciated,
Lena
Reply #1 on: April 02, 2025, 04:35:35 PM
You can put a 2A fast blow fuse in there to see if that helps.  Periodically blowing fuses tend to suggest there's something that needs attention.
