20 Ohms at 9 [resolved]
Dread31 · 1617
Offline Dread31
on: May 03, 2025, 02:22:23 AM
 When performing resistance checks, I get 10k ohm at 19 but 20k ohm at 9. Double and triple checking solder joints, I did discover and reflow two joints at A8 and A1, but the problem persists. No other bad joints have been found. All grounding points also seem to be solid.
Any ideas or input will be appreciated.
Rock On!
Dave Read
« Last Edit: May 17, 2025, 08:56:50 AM by Paul Birkeland »
Offline Dread31
Reply #1 on: May 03, 2025, 05:09:33 AM
Sorry about the sideways, over-expanded pictures. I'll see if I cant get better photos........
Reply #2 on: May 03, 2025, 06:47:44 AM
The wiring is there that should allow this resistance to appear correctly.  What I do see is a lot of joints that just don't have enough solder on them.
Offline Dread31
Reply #3 on: May 03, 2025, 11:09:13 AM
Okay, Thanks, Paul. I'll get busy on that.
Reply #4 on: May 03, 2025, 11:22:42 AM
You can also check the resistance of every terminal on each pot where a black wire lands.  They should all read 0.
Offline Dread31
Reply #5 on: May 03, 2025, 03:19:26 PM
Will do.
I fattened up all of those lean joints and the reading at 9 came down to 15k. So, were getting there.
Thanks.
Offline Dread31
Reply #6 on: May 16, 2025, 01:58:32 PM
Paul, it turns out I had the red wires on both tube sockets wired A5 & B5. Moved both to A6 & B6 where they belong. Problem solved, sounds wonderful. I did also find three weak solder joints and re-flowed them, adding a bit of solder as well.
Thank you for your time and assistance, Kind Sir.
Bottlehead is truly a class act.
Dave Read
