Kaiju/ Beepre2 Equalizer
blackharp · 534
Offline blackharp
on: May 08, 2025, 06:21:11 AM
Is there any way to integrate an equalizer, tone controls or similar into the circuit? If not, is there a cost effective hardware solution? I seem to be missing a bit of lower midrange and/ or fullness I get out of my Fisher and McIntosh amps on certain music. Jazz horns sound great connected to my Altecs. I know this is sacrilege to some.  ;)
Thank you all in advance and as a side note, I just missed another crack sale.  >:(
« Last Edit: May 08, 2025, 07:01:13 AM by blackharp »
Reply #1 on: May 08, 2025, 07:51:29 AM
Which Altecs do you have and what impedance configuration are you using on the output transformers?
Offline blackharp
Reply #2 on: May 08, 2025, 08:35:04 AM
604-Ds and I believe 8 ohm, but I can't remember 100%.
Reply #3 on: May 08, 2025, 08:44:16 AM
604-D is nominally 16 ohms. If that is the case with yours, using the 16 ohm output configuration of the Kaiji OTs should give a slightly fuller bodied sound.
Offline blackharp
Reply #4 on: May 08, 2025, 10:29:29 AM
Thanks, Doc. I'll double check how I wired the amp. These are my only 16 ohm speakers and I like to switch them out occasionally.
Offline Altecboy
Reply #5 on: May 08, 2025, 11:36:10 PM
I have Bottlehead Monamour mono blocks driving Altec Model 19 clones.  I use a Schiit Lokius: a 6 band equalizer.  Adjustments at 20, 120, 400, 2Km, 6k and 16K.  $300.  I have also used the Loki Mini Plus, 4 bands, $150.  These are unbelievably transparent and effective.  I recommend them highly. And, you get a 15 day trial.
