Buzz on left channel
Tabaia · 1493
Offline Tabaia
Reply #15 on: June 30, 2025, 08:57:48 PM
Ah Yes, I had done that already but will give it another go.
« Last Edit: July 03, 2025, 05:12:35 AM by Paul Birkeland »
Offline Tabaia
Reply #16 on: June 30, 2025, 09:11:59 PM
I Presume the readings are fine?
Reply #17 on: July 01, 2025, 04:57:34 AM
There isn't anything in your DC voltages that indicates a problem.
Offline Tabaia
Reply #18 on: July 01, 2025, 05:15:11 PM
Hello Again,
Still trying to problem solve the buzzing.
Have again and quite meticulously while the amp is on and with headphones  gone through with a bamboo skewer and probe'd all wiring, listening for any changes but could not detect anything.
Also gently wiggled the transformers. Agin could not detect anything.
Kindly advise of the next step to take.
Many thanks
Reply #19 on: July 02, 2025, 04:23:01 PM
Can you post build photos?  What kind of solder was used on the build?
Offline Tabaia
Reply #20 on: July 02, 2025, 05:24:30 PM
After going through all the soldering joints cables , tapping on the chassis, tapping on the components, looking over the whole unit in detail I finally turned it over and pulled the tubes out reinserted them a number of time.
Not it works perfectly again.
Thank you all for your support.
By the way I used the Cardas solder.
