Magnequest Iron for 45 / Top Plate Biasing / Chokes in the Power supply / Etc
Paully · 9142
Offline Paully
Just wanted to take a minute to update a couple of different threads for anyone who cares.  Thought I would just do one post instead of posting all over the place.  First, we (Grainger and myself) installed chokes in the power supply of the Paramounts.  Nice upgrade as I have stated elsewhere.  Having converted my amps to 45 I also ordered Magnequest output transformers in full nickel with a 5K impedance and also ordered some plate chokes.  As Paul Joppa has indicated, a very nice upgrade.  I realized just how fantastic the transformers are that are stock in the Paramounts but this was an improvement.  Don
« Last Edit: April 16, 2011, 04:45:55 PM by Paully »
It was pretty gratifying to get so many projects knocked off in 2 1/2 days.
Edit: In the second picture down from the top you can see the red and green wire we used since we didn't have any STP left over from Paul's builds.  I chucked the two ends into a battery powered drill and slowly started to twist them together.  Then sped up the drill and made 3 feet of tightly twisted wire in about 10 seconds.  My first try and it worked beautifully.
« Last Edit: May 01, 2011, 01:35:27 AM by Grainger49 »
Offline shelby1420
I'll bet guys, thats a boat load of work, nice work!!!!!
Enjoying the music
Rick
Hi Paul,
Can you post the changes you made for the 45 conversion with the exo-46 -- or 45 as the case may be?  Just in case I et the itch to try this at some point down the road with a 5k opt?
Offline Paully
Do you want a step-by-step?  No problem if you do.  As far as changes, as Paul Joppa pointed out in another post, changing the output transformers requires a change in the coupling caps, if I have it right, due to the change in impedance.  Unless you change the chokes too.  But if you do one or the other you need to change the coupling caps.  Since I tend to buy decent coupling caps it was the right move to go ahead and buy the plate chokes and not have any other expense.  That way you are just putting in the chokes and transformers, no other changes necessary.  I ended up using the EXO-45 with 8 ohm impedance.  If you want a write-up of the hook-ups let me know and I can get it for you.
« Last Edit: May 01, 2011, 01:34:11 PM by Paully »
Paul,
Don't need the pictures :-).  And I also don't need any step-by-step info, just what component value changes you made to cathode resistors, power supply, soft-start board, etc. to accomodate the 45 with a 5k opt.  I'm asking because PJ mentioned in another thread that some things would have to be reworked to use the 5k opt, and I'm just wondering what those component changes are.  I've got a paramount manual now, but still have to wait to order my soft-start boards.
Jim
Offline Frank Mena
Reply #6 on: May 02, 2011, 05:12:40 AM
Just out of curiosity.... what speakers are you planning to use after the conversion to the 45?
Cheers
FM
Foreplay 2, Paramour with iron upgrade, Seduction, Theater 4 pi Speakers, DIY TT with Jelco 750 tonearm and Denon DL103R with cinemag steups
Frank,
If you mean me, I'll be using them with an upgraded pair of Cornwalls, which will actually be Cornscalas in cornwall enclosures and will use Klappenberger crossovers to give a 6-8 ohm impedance that is almost purely resistive.
Paul has some kind of Altecs.
Paul has the Valencias with new crossovers he built with the best components he could afford.  It was a noticeable step up when he did it.
« Last Edit: September 19, 2011, 07:54:05 AM by Grainger49 »
Offline Paully
I had a nice post written up, but I hit the wrong button and lost it.  Just read this http://www.bottlehead.com/smf/index.php/topic,895.0.html.  Only thing I would add is at 120V from the wall I needed to add another 680 ohm resistor in series with the two 3K to get my voltages down.
I have the Altec 846A.  Very efficient and no problems with the 45.  I also played some Klipsch Chorus II with them and found volume to be more than sufficient so your Cornwalls should be fine.
« Last Edit: May 02, 2011, 05:49:23 AM by Paully »
I can't find the post right now, but as I recall I made some calculations specific to Paully's power line voltage as well as the 5K transformer impedance. (Or was it someone else? Seems to have been more than one thread on the 45 conversion lately!)
Anyhow, in most cases you can reduce the driver plate voltage, which will increase the 45 plate-to-cathode voltage and reduce the current so that it matches a 5K impedance. In some cases you might get too much current or voltage or power in the driver, in which case the 6000 ohms cathode resistance can be increased. Since the increase is small, you can get away with a third resistor that has a lower power rating, and this third resistor can replace the wire that connects the two 3000 ohm resistors in series. That makes is a simple modification. I have a clunky and unreliable spreadsheet, not good enough to post but I'll do the calculations whenever they are needed.
I hope everyone understands that the Paramount was designed for the 300B and 2A3; the 45 modification is not a standard thing. It's theoretically possible to run a Type 50 too, though you'd have to use a grid choke which has some hum risk. The Paramour II and Stereomour were designed for the 45 and 2A3, and as I've said I have plans for a shunt regulated 45 amps as well.
Offline johnsonad
This is what I'm waiting for :)  Yesterday I was reading posts back to 2004 on the Magnequest board regarding a SR 45 amp at least in theory.
Hey Paully, do you have less bass with your Altec's compared to driving them with a 2A3?  In my Fi amp the 45 sounded wounderful except for the lack of low end.
Offline Paully
I have noticed no loss in bass with my Altecs, but the speakers never dug that low to begin with.  Maybe, maybe the really low bass but my audio memory is such that I haven't really noticed (and thus I can choose not to care).  I had been planning on a powered sub-woofer for a while now anyway, even before the change.
Just out of curiosity, Paul, what would you do differently with an amp to optimize it for 45/2a3 versus one that is 2a3/300B besides the output transformers, plate chokes, and cathode resistors?  Already did that.
Build a 45 amp and I might just have to do something that will get me in more trouble.  I can hear it now, "Why do you need another amplifier?  Is something wrong with the one you have?"  I usually just answer yes, yes there is.
Offline johnsonad
LOL, it's often easier that way right Paully!  My wife does help me from collecting too much stuff in closets though!
