Seduction bass performance question.
SPaulMac · 53390
Offline SPaulMac
Reply #15 on: May 07, 2011, 09:58:18 AM
Grainger,
The 6N23P-EV tubes sound interesting and look to be well thought of for the price. Any suggestions on a reliable source? If found them at Cryoset for what appears to be a decent price, but frankly I'm getting either love 'em or hate 'em concerning dealing with Cryoset on various forums.
Stephen
Stephen Morris
Shure V15-VMR
Rega Planar2
Bottlehead Seduction
Marantz SA8260 SACD
Pioneer RT-707
MacBook Pro via HRT Music Streamer II
Adcom GFP-565
Adcom GFA-555
Magnepan MMG
Bottlehead Crack
AKG K501
Offline garrardfisher
Reply #16 on: January 18, 2014, 04:39:12 AM
I'm reviving this thread, because I feel that my question is on topic and I can't find any other threads regarding lack of bass on a Seduction.
I use my Seduction in a system with a KT88 SE power amp (~5-8 wpc), a Forewatt preamp with gain (no tone controls) & a Shure M91e MM cartridge (5mV) and Advent 5012 speakers (87dB sens).  I have been living with almost no bass, just assuming that I needed subs or more efficient speakers.
Just for kicks, I did a test and took the Seduction out of my system and used my Marantz 2230's preamp/phono stage to drive the KT88.  I got deep, plentiful bass with this system.
Then to make sure this new-found bass wasn't just the false boost of the preamp/tone control of the Marantz, I ran the Seduction into the Aux input of the Marantz.  Weak bass again, same tone settings.....bass cranked.
I conclude that (1) the KT88 is capable of providing enough power for deep bass on my Advents and (2) it isn't the tone control circuit of the Marantz that delivers the bass, it is the RIAA circuit.
So, any suggestions as to why the Seduction has weak bass?  I took the advice given to SPaulMac in this thread and tested the resistance and continuity points of the RIAA circuit (they WERE tested post-build).  Nothing wrong there.  I also confirmed that I have the correct capacitors in the RIAA circuit ( .033uF, not .33uF).  I haven't tested capacitance yet, but I can't imagine that both R & L channels have failed caps.
Thanks in advance.
Brian
Reply #17 on: January 18, 2014, 04:45:27 AM
I can say that with a stock or C4S upgrade build the bass is just fine through the Seduction.  Mine fed a Foreplay 2 then a Krell KSA-250S driving Fuselier 3.8D speakers.  It would kick you out of the room.
I can only conclude that the circuit is not exactly right.
« Last Edit: March 31, 2014, 03:55:49 AM by Grainger49 »
Reply #18 on: January 18, 2014, 04:56:12 AM
That's gotta be it.  (by the way, the Marantz phono gain is 40dB, so not much different than the Seduction's gain).
Anyone know where I can get the voltage test points and values sheet?  Also the schematic (so I can tell where to measure?).
I built this kit over a year ago and lost or tossed the instructions..
Reply #19 on: January 18, 2014, 04:58:55 AM
PM your email to me and I will scan my schematic and test values.
« Last Edit: March 31, 2014, 03:53:33 AM by Grainger49 »
Reply #20 on: January 18, 2014, 07:21:36 AM
This problem has come up before. The two most likely causes are an error in the RIAA circuit, or a failure of one of the bias LEDs. The resistance and voltage checks will most likely provide enough information to diagnose the problem.
Reply #21 on: January 18, 2014, 07:59:49 AM
I sent the schematic, resistance and voltage checks to him.  I'm sure he will post when he gets the data together.
« Last Edit: March 31, 2014, 03:52:30 AM by Grainger49 »
Reply #22 on: January 18, 2014, 09:10:59 AM
Terminal      Voltage
26,36          0,0
27,37          69.4, 71.9
29,39          68.7, 70.9
30,40          70, 73.6
34,44          134.6
32,42          73.5, 69.9
I don't see any major problems there.
All 4 LED's light up....is that not a guarantee that they are good?
Reply #23 on: January 18, 2014, 09:25:32 AM
If the LEDs light, they are good.  They will have 1.5V across them when lighted.
I'm not looking at the expected voltages now but if you are within 15% either way, you are good.  I expect something in the RIAA circuit.  The Capacitors are the major part of it as are the 66.5k, 9.64k and 1M Ohm resistors.
Verify those values.
« Last Edit: March 31, 2014, 03:51:51 AM by Grainger49 »
Reply #24 on: January 18, 2014, 09:48:17 AM
Resistors are good.   66.4K & 66.5K     .997Meg & .999Meg
I'd sure like to avoid de-soldering 6 caps in order to measure their capacitance.  (If necessary, I will)
Besides that, it seems logical that this would be a problem that involves a component that is common to both channels because neither has sufficient bass.  If it were only one channel, I would suspect an RIAA circuit capacitor and be able to focus on that channel.
I verified continuity between the ground side of the 10n, 1.2n & 33n and ground plate.  All good.
Reply #25 on: January 18, 2014, 09:54:08 AM
BTW, all voltages are within 5%.  The B+ is 9% low. ( should be 150, I measured 136.4)
Offline saildoctor
Reply #26 on: January 18, 2014, 03:10:39 PM
Hi Brian - is the Seduction stock or does it have the C4S upgrade?  What kind of tubes are you using?  Are the output caps the stock 'Orange Drops'?  You are dead certain that the each cap is where it's supposed to be right?  I remember I nearly goofed swapping some (the 33nF and 0.1uF I think) when I build mine because the ones I got were so similar looking.
« Last Edit: January 18, 2014, 03:16:13 PM by saildoctor »
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
Reply #27 on: January 18, 2014, 03:23:23 PM
Yes, the tube voltages look good, so it is probably not a bad tube.
The bass is controlled mainly by the 66.5K resistor, the 9.64K resistor, and the 0.033uF capacitor. A bad solder joint in this region would kill the bass. So:
Check resistance between T37 and T39, should be 66.5K. T37 to T40 should be 75K. Now get some clip leads if you don't have them (cheap ar Radio Shack, very handy!) and shore out the capacitor leads of the 0.033uF. Then measure resistance T37 to ground; it should still be 75K.
No good? then maybe the 0.1uF is not connected. Resistance from the lead that goes to T36, to ground, should be 1.0Meg.
Notice I am asking for cap leads, not terminals - so the solder joint between them is tested.
Reply #28 on: January 18, 2014, 04:29:26 PM
Stock, no C4S upgrade (yet).  6922EH tubes.  Yes, orange drops.  Yes it is easy to mix these up, but I am dead certain about the caps and their locations (double checked with a cap number code chart).  Thanks for the suggestions, I really appreciate it.
I tested the resistance per Mr. Joppa's advice.
T37 and T39 = 66.5K
T37 to T40 = 75.9K
T27 and T29 = 66.4K
T27 and T30 = 75.7K   (I'll have to buy aligator clips tomorrow, I don't have any)
That is if I have the probe on the bare metal of the terminal.  I can't understand why my DMM sometimes doesn't register when I put the probe on the solder.  Solder is conductive right?  Typically when I can touch the lead where it pokes out of the solder, then I get a reading....weird.
Maybe that is how my .1 coupling cap might be disconnected.  Really odd that both channels would be disconnected, even though soldered in place.
I will double check my 0.1uF connection and all connections in the RIAA circuit tomorrow.  The terminal eyelet is filled with solder, but maybe I didn't wrap the lead around the terminal well.
Please stand by.... ;)
Reply #29 on: January 18, 2014, 04:39:38 PM
Continuity is good on the .1uF caps.  I probed the leads of the 220ohm and 66.5Kohm resistors and the .1uF lead.  So the solder joints are OK.
I also confirmed the continuity of the 10n, 1.2n & 33n caps the same way.  Probed the leads to test the solder joints.   :o
