K1000's and 2A3 Paramount?
johnsonad · 4814
Offline johnsonad
on: May 22, 2011, 01:02:52 PM
Just curious if anyone has used their K1000's with Paramounts set up for 2A3's and your impressions?
Offline xcortes
Reply #1 on: May 22, 2011, 04:15:03 PM
I have used k1ks with a Sex amp and to me the combination was very good. So my experience tells me they should be very nice with the 2A3s. Particularly if you use the 16 ohm tap. having said that I'm in the process of building a pair of 300B amps for them. I will be using 5k transformers so power output will be in the 6 watt range.
Xavier Cortes
