LED Indicator
Dr. Toobz · 6801
Offline Dr. Toobz
on: June 06, 2011, 05:11:54 PM
With the tube shields on, it's hard to tell when the Seduction is running. Would there be any issue with sticking a common orange or red LED in one of the holes meant for the Hammond box (not needed in my case) and then running the LED, in series with a 1000 ohm resistor, in parallel with the two 6.3V tube heaters? I'm assuming this would only add about 20mA of current to the winding, depending on the LED?
Reply #1 on: June 06, 2011, 06:57:45 PM
Should be no problem.
Offline debk
Reply #2 on: June 06, 2011, 11:08:42 PM
I did it with a blue LED.  worked great
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline Pfenning
  • My knockoffs
    • This is the place
Reply #3 on: January 19, 2012, 12:36:22 PM
Can someone give me a little instruction how to wire this in? I get the resistor and LED part, but where is the best place to tie it in?
Thanks, Pfenning
Pfenning
Offline porcupunctis
  • 0D3
Reply #4 on: January 19, 2012, 03:20:03 PM
Would there be any problem using a 120V indicator lamp?  That should be easy to wire and wouldn't require a resistor to drop the voltage off the mains.  I'm pretty sure I have a few out in the garage in one of my bins full of parts.
Randall Massey
Teacher of Mathematics
Reply #5 on: January 19, 2012, 11:59:03 PM
An incandescent light, not neon, adds no noise.  Can you find one at 120V?
Offline Pfenning
  • My knockoffs
    • This is the place
Reply #6 on: January 27, 2012, 05:48:33 PM
Found a 120 vac lamp at the Rat Shack in a 2 pack for $4. Had to drill out one of the existing unused mounting holes to 1/4" and slipped it right in. It worked really good, I might add one to all my Bottlehead gear. It's easier for my kids to see if it's on or off. I also bought some 3/16" black plastic hole plugs for the other 3 holes. Sounds silly, but it gave it more of a finished look.
Pfenning
