What tubes are you running in your Seduction?
castelletti · 20215
Offline castelletti
on: June 24, 2011, 05:31:13 PM
I have a Seduction w/ C4S upgrade and am wondering what others like to run in theirs.  So far I have run the following.
EH 12AU7's that came stock (thats 6922 dummy!)
Amperex PQ Orange Label  (NOS)
Valvo Red Label E88CC (NOS)
The Amperex and Valvo's  sound similar character, however the Valvo's have extended top and tighter bottom end.  However both tubes make noise when I turn up the Crack to about 11'oclock, and while the EH's are quieter they sound very thin in comparison.  All of them are microphonic, not that its a deal breaker for me.  It seems like this "family" of tubes is microphonic as I went through a friends stash and all of them are to some degree.
Just wondering what you guys are running out there.  I still feel improvements can be made.
« Last Edit: June 24, 2011, 06:12:03 PM by castelletti »
Offline Dr. Toobz
Reply #1 on: June 24, 2011, 06:04:52 PM
.....EH 12AU7's that came stock
I think you mean EH 6922's. 12AU7's wouldn't work well in this amp!
I'm still using the stock EH 6922's myself.
Offline castelletti
Reply #2 on: June 24, 2011, 06:10:43 PM
duh...lol  too much tube rolling today....lol  yes, the 6922's
Reply #3 on: June 25, 2011, 04:27:31 AM
I have in a set of 6n23P-EVs, the Russian military equivalent.  This is a ruggedized tube which will have lower microphonics.
Edit: Lee, thanks for reminding me of the -EV.  Those are what I'm using and the suffix is important.
I sould mention that these tubes are exceptionally clean and have beautiful soundstage.  The tonal balance is not tilted toward any range that I am aware of.  Not to mention they are inexpensive!
Here is a thread with a list of 6922 equivalent numbers:
http://www.bottlehead.com/smf/index.php/topic,1029.0.html
« Last Edit: September 19, 2011, 09:20:43 AM by Grainger49 »
Offline Lee Hankins
Reply #4 on: June 25, 2011, 06:04:15 AM
I have used the 6n23P-EV and really liked their sound, excellent sounding tube for the money, but I have settled on the CCA version of the 6922.
Cordially,
Lee Hankins
Lee Hankins
"End of the Road"
Homer, Alaska
Offline castelletti
Reply #5 on: June 25, 2011, 06:23:16 AM
What is it about the CCA's that you like versus other tubes?
Offline barry robin
Reply #6 on: June 26, 2011, 12:51:07 AM
i was using Telefunken ec88's until one died; i'm now using (Amperex) dario miniwatt EI88CC's. love 'em both for the liquidy thing they do.
Offline Dobs
Reply #7 on: July 27, 2011, 05:42:16 PM
Russian 6n1p-EV, but required heater supply and RIAA network modification over stock Seduction.
Offline Blooze
    • My Electronics Pics
Reply #8 on: September 28, 2011, 08:05:54 PM
Been running the Sylvania JAN 6DJ8's that came in the kit.  Heck, I have a C4S kit I've never bothered to build because the rest of the chain is so weak that it'd be pointless.  I tried some EH 6922's, but the bottles are too big in diameter to fit in the shield on the socket.
« Last Edit: September 28, 2011, 08:08:49 PM by Blooze »
Offline Laudanum
Reply #9 on: September 29, 2011, 07:12:17 AM
Hmmm, my Seduction came with the EH's and they fit in the shields.  Well, atleast in the bases, I never used the tubes other than the Voltage checks so didnt use the shields.
Anyway, Im using the 6N23-EV's as well.  Nice sounding tubes and quiet.  But I have a couple of Bugle Boys I'll get around to rolling in.  Also a couple of USA Amperex and some Westinghouse labeled 6922's and Jan Phillips.  I have a Valvo E88CC Gold pin and a Valvo ECC88.  I'll have to see if I can find an affordable mate for each of them and if so, I'll have a couple more nice pairs.  All of these on hand already from two tube CDP's that take 6922's that I purchased 10 years ago.
Desmond G.
Offline Blooze
Reply #10 on: September 29, 2011, 07:19:50 AM
Hmmm, my Seduction came with the EH's and they fit in the shields.  Well, at least in the bases, I never used the tubes other than the Voltage checks so didnt use the shields.
Mine won't fit in the short shield base that's part of the socket.  No way they would fit in the shield "caps" as well.
Offline Laudanum
Reply #11 on: September 29, 2011, 08:49:17 AM
Different shield bases and caps I guess???  Or, fatter EH 6922's
Desmond G.
Reply #12 on: September 29, 2011, 10:30:01 AM
Yes the Russian tubes are inconsistent in terms of outside diameter. Also, double check the spec on the E88CC before you try it. It is a little different than an ECC88.
Offline Laudanum
Reply #13 on: September 29, 2011, 10:57:19 AM
Thanks Doc.  I dont have a mate for either tube so just maybe that will save me time and money on the E88CC :-)
Desmond G.
Offline barry robin
Reply #14 on: September 29, 2011, 09:40:26 PM
...double check the spec on the E88CC before you try it. It is a little different than an ECC88.
were you referring to my use of the EI88CC's? or specifically the E88CC? mine run just fine.
-b
