self bias circuit removal removal risks and rewards
Davenportt · 24704
Reply #15 on: April 03, 2012, 08:18:41 AM
Just checking here, the diode you used, is it this one:
HLMP-6000
http://ca.mouser.com/ProductDetail/Avago-Technologies/HLMP-6000/?qs=sGAEpiMZZMs4quMj8r4lmvKuq%2flfwXl0ro7P6wPamrM%3d
I could use a few.
« Last Edit: August 31, 2012, 02:26:10 AM by Grainger49 »
Offline grufti
Reply #16 on: April 03, 2012, 09:35:14 AM
The Avago HLMP-6000 types [that's the tiny Bottlehead LED] has been giving me the lowest bias voltage values. For most tube triplets [2xEF86 and 1x6922] that has resulted in the best combination operating points, i.e. something like 95V plus for the EF86's and about 160V for the 6922.
It still took some swapping around to find combinations that bias up properly.
The setup that I have right now actually uses standard red LED's, because the lower voltage of the HLMP-6000 [about 1.56V] had the EF86 tubes at 107V and the 6922 at about 150V. The standard red LED gives me about 1.65V.
Try measuring your bias voltage with the servo still in place. That should actually give a pretty good indication of where you need to be, if I'm not completely mistaken.
Reply #17 on: April 03, 2012, 10:17:15 AM
Thanks, I will do that.  I have been meaning to buy a hand full of these so I will go ahead.  I have a  number of old red LEDs I might give them a try also.
And thanks for the voltage targets.  You saved me a lot of digging.
Offline Prairie Dog
Reply #18 on: April 03, 2012, 01:40:13 PM
I think a light may have finally gone on inside this dull head of mine.
Thank you
Reply #19 on: April 03, 2012, 01:49:55 PM
Yes, it's worth being concerned. No, don't change the resistors - it's direct coupled, and every change you can think of affects both tubes - you have to achieve the desired voltage and current in both tubes all at the same time in order to get proper operation - that is, correct equalization, correct gain, and correct (low) distortion.
If the 6922 plate to cathode voltage is low, then the grid to cathode bias voltage difference is also too small, and grid leakage current provides a shunt resistance which reduces the maximum gain of the first stage. Bottom line - improper equalization and less bass. Each individual 6922 or whatever else you have in that position will have a different threshold of critical leakage, and it will change with age - the design operating point assures that most tubes will work correctly most of the time. This is exactly the reason we went to a servo bias - so that most tubes would not exhibit this problem.
Offline Prairie Dog
Reply #20 on: April 03, 2012, 02:39:09 PM
Thank you for clarifying this further for me.  I wish I knew more about the theory behind it all, maybe I wouldn't get hung up on every mod I read about!  You pretty much nailed it with the equalization - while the highs are more open and detailed, the bass is a tad thinner.  I'll likely go back to the servo config as the amp is amazing as designed - and had been trouble free with pretty much any tubes I plugged into it.
Thanks again
Offline johnsonad
Reply #21 on: April 30, 2012, 07:21:49 PM
Hmmm, well mine isn't working so well.  The 6BR7's are only getting around 70 to 75v and the 6922 plate to cathodes are 114v and 112v.  Is it me or the 6BR7's?  Am I going to have to convert these over to EF86?
Offline grufti
Reply #22 on: April 30, 2012, 07:59:28 PM
You might be able to get there by changing the type of LED that you are using. Different types of LED have different forward voltage drops. What kind of LED are you using now?
Offline johnsonad
Reply #23 on: April 30, 2012, 08:27:15 PM
I'm using the standard Avago HLMP-6000 that Bottlehead provides with the kits.  Could you specify a part that might work better and a voltage range I should be looking at?  LED specs get a little confusing for me.  Thank you!
Offline grufti
Reply #24 on: May 01, 2012, 06:05:52 AM
I use small indicator LED's with low light output (mcd) values just so they don't light up the whole room from underneath the chassis.
You should measure the voltage across the HLMP-6000 so that you know where you are at now. Other red LED's will give you a very similar voltage. Green ones are usually the next step up in forward voltage, then yellow. I haven't looked at specs for blue or white LED's in some time. Another interesting type of LED are the IR (infrared) ones. They typically have a forward voltage drop around 1.2V.
So basically what you can get is: just around 1.6V with the HLMP-6000, a bit more with other red LED's, 1.7+V with small green indicator LED's, 1.9V with yellow ones, 2.3+V with two IR LED's in series. There must be other LED's out there to fill the gap between 1.9V and 2.4V I just haven't had to look.
How easy is it for you to go back to the servo circuit on one channel? It would be helpful to know what your bias voltage is with the servo circuit in place.
Reply #25 on: May 01, 2012, 10:47:28 AM
The HLMP-6000 was selected some years agon by John "Buddha" Camille, for its exceptionally low noise and its low dynamic impedance. Other diodes will have different voltages and impedance - by the way, there are several different red formulations.
The direct couple circuit has some negative DC feedback to stabilize the operating point, derived by feeding the EF86 screen from the 6922 cathode. (Incidentally, the 'Tode guitar amp under development has the same circuit - an old Mullard innovation.) Most old-stock EF86s are close enough to the spec that they will bias up correctly with the design choice HLMP-6000. Modern production EF86s are less consistent and many need a greater amount of DC negative feedback, provided by the servo circuit.
Obviously tubes that differ further from the EF86 specs can sometimes be made to work by the servo, but would be especially unlikely to work without it.
An alternative to the servo bias is adjustable bias, in the present case substituting other diodes until the right operating point is achieved. Unless you have access to tube curves at 100v on the screen, it is impractical to predict what the bias should be - I had to develop my own EF86 curves to do the original design. I have another adjustable bias in mind, but have not had a chance to test it yet - and I won't share it until I know whether it works, sounds good, and is quiet. Risks of changing the bias scheme are noise and distortion. Risks of changing tubes are noise and RIAA equalization accuracy - the tube's plate resistance is incorporated into the equalization, primarily affecting the 50Hz low frequency corner.
We elected not to pursue such a design because it requires re-adjustment as the tube ages and whenever tubes are replaced, including rolling tubes. It's not just the practical difficulties, I also worry that too many Eros' will be operating out of adjustment, sound bad, and create a poor opinion of the Eros.
Offline johnsonad
Reply #26 on: May 01, 2012, 02:16:27 PM
Thanks guys.  I will rewire one of the channels for EF86 and restest.  With the Tube Phono at home I've collected a few that should work nicely.
Offline johnsonad
Reply #27 on: May 02, 2012, 07:53:57 PM
Alright, a little update.  As I've got a stash of these 6BR7's I reinstalled the servo's and measured.  Not good...  Here is what I'm getting with the 6BR7 and 6922: 52.7v/96.7v, 58.3v/ 94.2v.  As it stands, none of my voltages are w/in range.  So I converted one channel to EF86 and restested; line voltage is 119.6v (50Hz)
With servo: 60.2v/ 95.4v
With LED and Winged C EF86: 84.6v/85.1v
With LED and CV4086: 61.3v/95.1v (this voltage changed for some reason after I swapped tubes and never returned to this level)
Edited to save on posting.  I converted the other channel over and have found that not all tubes are the same.  Here are the final results with CV4086 tubes (the best of the four):
R 71v/ 89.3v on EF86 cathode
L 70v/ 93.3v on EF86 cathode
PJ, my voltages are good for the 6922 but a little low for the EF86.  Do I need to keep trying tubes until I get it right??
« Last Edit: May 02, 2012, 10:20:53 PM by johnsonad »
Offline DrewTube
Reply #28 on: September 23, 2012, 05:27:50 PM
Argh...darn me for reading this forum and getting obsessed about mods.  I just HAD to try it.  Ugh.
So I have a pair of Telefunken EF86's and a spare pair of the Avago LEDs, so I figured I would give this a try.  The actual mod was easy and went very smoothly.
My plate voltage for the EF86 (measured from OB to ground) is now ~105v (vs. ~95v with servo).  My 6922 plate is now ~150v and the 6922 cathode is ~105v (vs. ~160v and ~97v with servo).
So, my EF86 plate voltage is in-range, but the 6922 plate to cathode gap is now too small (right?).  This may be a noob question, but does this mean my LED bias voltage (1.54v) is too high or too low, e.g. do I want something closer to 1.3 or to 1.7v?
Profuse thanks in advance.  BTW, the Eros ROCKED until I started messing with it.  Thanks for an awesome kit!
Drew
Reply #29 on: September 23, 2012, 05:40:00 PM
You'll need a more specific voltage reading of the cathode voltage of the 6922 and the plate voltage of the EF86, see if you can grab the first decimal place and report back (you can also listen, it's very audible when things aren't in check).
