New Foreplay build Questions
mchurch · 13192
Reply #15 on: October 16, 2011, 05:40:30 AM
I you still have the SW that you just replaced. You can use it as a 15K variable resistor to experiment with...John
Offline mchurch
Reply #16 on: October 16, 2011, 02:18:37 PM
Mike,
If any of the diodes you have tell you what current they draw we can calculate the series resistor easily.
Grainger49, I am going to take a look a potential candidates for LED later this evening I will look for their current draw.
Mike
Offline ajp
Reply #17 on: December 11, 2011, 03:48:26 PM
Hi, I just completed the soldering potion of the build. But I notice that I never read, that I should solder the drain wires to 28U. Have I missed that in the instructions. That seems wrong, won,t they move around etc.
albert prio
Offline Laudanum
Reply #18 on: December 12, 2011, 02:51:08 AM
If I recall, there were one or two minor misses in the FPIII manual.  That seems to be one of them, from memory.   Yes, they should be soldered.
Desmond G.
Offline ajp
Reply #19 on: December 12, 2011, 08:53:25 AM
Thanks, that's what I though.
albert prio
Offline ajp
Reply #20 on: December 12, 2011, 03:33:00 PM
Hi, My OD3 is glowing but the 2 12AU7's don't. I'm getting only 2.3 VAC  on 4, 5 and 123.5 on 6 of the transformer terminals. The wiring looks good. Any ideas?
Al
albert prio
Reply #21 on: December 12, 2011, 04:04:52 PM
Check the orientation of the diodes and the capacitor back there. It has been a source of difficulties a few times. If there is an error, check the diodes and inspect the capacitor for signs of swelling - they may have been damaged.
Offline ajp
Reply #22 on: December 13, 2011, 12:20:17 PM
Thanks Paul. When looking at the capacitors I found a solder I just plain forgot. All the tubes are glowing.
Back to testing
Al
albert prio
