Fostex FE126 EN, in Madisound BK-12M kit
Noskipallwd · 48533
Reply #15 on: October 08, 2011, 01:09:59 PM
Yeah, I think that 99 out of 100 owners of LE8-Ts are shocked at the JBL kit cost and simply refuse to get it - and get angry at the dealer who tries to sell it to them. So, many won't even mention it. In a lot of cases, these were just ceiling PA speakers - that's how I acquired four of the alnico ones  :^)  New surrounds come with a new cone, voice coil, and dust cap - that's worthwhile because the aluminum dust cap has a foam damping parch on the inside, which is probably in as bad shape as the surrounds. I spent something like 10 times the purchase price to get them re-coned.
Offline Laudanum
Reply #16 on: October 08, 2011, 04:03:25 PM
oh-oh ... how much does JBL charge for the kit for a pair if you dont mind me asking?
Desmond G.
Reply #17 on: October 08, 2011, 05:06:59 PM
WTF?!?!?!? Have I ever heard these? Did you ever put them in an enclosure and hit them with signal? Oh, the inhumanity!
Sorry, just coming off a day of moving a few parts of a Hammond model E organ/speaker complex, including two D-20 speaker cabinets with two each Jensen A12 field coil drivers. So I'm in the "vintajjjjj" mode.
Reply #18 on: October 09, 2011, 01:26:08 PM
No, they are still sitting in their shipping boxes. Two are LE8Ts, two are reconed as 2115s, plus I have a pair of D-208s - all 8-inch fullrange JBLs. Never had a suitable box. Needs to be, oh, about the size of the Thrasher, actually...  :^)  Seriously, I think I'll get a pair of those.
Offline Noskipallwd
Reply #19 on: October 10, 2011, 02:50:32 AM
Hello again,
Thought I would give an update. By the way, I think I'll avoid the JBL LE8-Ts. I built The BK-12M kit, it was an easy build, the cabs went together well. Just make sure you have enough bar clamps! I have not done any finishing, still just bare Baltic Birch. Well, right out of the chute the Fostex drivers were harsh and shrill. Kind of like a neighborhood cat in heat. So I ran Graingers break-in method using my music server and gainclone. After 60 hours or so the Fostexs began to settle down. So I have done some listening with my cheap PP 16 watt amp and I have to say I am glad I decided to get this kit. Soundstage is excellent, they fit my listening area well. Lack in bass, but that was expected, and I don't think I will need to add a super tweeter. Symphonic, as well as vocals perform well on these speakers. I might look into adding a subwoofer for the Bass, although I am happy with classical and jazz as is. Now I need to build a Stereomour or some Paramounts so I can drive them properly!
Shawn Prigmore
Offline debk
Reply #20 on: October 10, 2011, 05:02:56 AM
I think you will find with even more time they will sound even better.
It took mine almost 300 hrs before I was really happy with them (mine are fe206's)
Enjoy them
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #21 on: December 01, 2011, 07:51:22 AM
Shawn,
Any more updates?  Having been through three iterations of another very similar design I can confidently state that these need a good 400 hours to break-in, but continue to improve slightly for probably double that length of time.
I don't know the design, but if there is an empty sealed chamber near the bottom, you can fill it with BBs and sand, or just a lot of BBs and that tends to make things even smoother and the bass still better.
You could also bolt them to a heavy maple block -- the michigan maple 12" x 18" x 4" ones work really wel and aren't terribly expensive -- they are just maple cutting boards.
These look really interesting, and an awful lot of speaker for the price.  I may just have to build a set to see how well they do with the s.e.x. and stereomour as I'm always looking for reasonable, high-value, decent sounding speakers for friends on a tight budget.
Offline Noskipallwd
Reply #22 on: December 02, 2011, 04:43:59 AM
Hey Jim,
I have put alot of hours on the Fostex drivers lately, I recently aquired a Jolida tube phonostage and have enjoyed running my LP12 and Concept through it.
Shawn,
Yes, the SQ is continually improving, and I have finally settled on the best placement for them. The soundstage is already excellent, now I understand the single driver thing. Well recorded symphonic vinyl sounds fantastic through these.
There is a small triangular space there, I'll have tap into it and give this a try.
They say great minds think alike! HeHe, actually I built stands for them using 1" square steel tube stock for frames with spiked feet in the corners. I bolted 2" thick maple cutting boards on top of the frames and the speaker cabs to those. They lifted the drivers to a better listening height, but the SQ change has been fairly minimal so far.
I would recommend these to anyone with a small listening area interested in great single driver full-range speakers that won't break the bank. They are a good bang for buck deal. I haven't been able to decide on how to finish them though, any recommendations?
Cheers,
Shawn
Shawn Prigmore
Reply #23 on: December 02, 2011, 05:05:46 AM
Shawn,
Finishing is always a matter of personal taste, but all kinds of possibilities are open with these because of the BB ply (which I think looks fine finished natrural, but can also be a lot of work, especially if using an oil finish on the end grain sections.  Wipe-on poly also works well, as does veneering -- I veneered my last pair of Horn Shoppe horns with australian lacewood and they came out beautifully and now live with a neighbor who loves them.  because the construction is not done with bevel joints and the eend grain is exposed, a good bit of sanding prep will be needed, and you should stick with paperback veneer and contact cement or a vacuum press and cold press glue -- raw veneer and heatlok glues will probably not hold up as well.
If painting, try to use one of the textured paints -- also because of the exposed end grain -- as the wood shrinks and swells, the textured paints will telegraph the seams much less than a glossy or even semi gloss paint.
All up to you, of course. but I think the textured paint can look really good on these and I'd probably do my pair in red instead of black, and Debk would probably do hers in purple :-).  For me, a stain annd wipe-on poly would probably be the next choice -- all depending on the room it is likely to be used in.
My eldest neice will be 11 in January, which means the following year she will get her first stereo from uncle Jim, and these are looking like a very  likely pair of speakers for her -- now I just have to find out what her favorite color is :-).
Thanks for the update and glad to hear they're doing so well.
Offline Capt.Z
Reply #24 on: December 05, 2011, 08:11:39 AM
Just discovered you post. I have Hornshoppe Horns, which use the Fostex FE126EN driver.
They play extremely clean. A couple of tube watts can play them above 110 db without distorting. Though I don't play them that loud, I have tried it, just for the fun of it. I also added a Fostex T90 Super Tweeter which even enhances the sound of the Horns. Secret is to cross them over rather high, like at 35 khz, using a 0.33uf cap. This way the Supertweeter does not add anything in the frequency the FE126 plays, but it 'continues' the upper Frequency response, which lets you see much deeper into the acoustical scene. Having the Supertweeter, I no longer would want to live without it.
Offline chrisby
    • commercial site:
Reply #25 on: December 05, 2011, 09:52:05 AM
Regarding JimR's post on veneering raw BB plywood  (such as the Madisound BK12 kit) - I've built more than a few dozen pairs over the years using the iron-on wood glue technique with quite satisfactory results (including the Macassar Ebony enclosures for Jim's Fostex F120As a couple of years back)
Aside from the most obvious issue with contact cement - no room for adjustment, there's also the potential for solvent based stains/finishes to penetrate paper backed or pure veneers and delaminate solvent based contact cement.
Yes, the butt joints and exposed edge grain will need good sanding and a glue-size pre-coat to eliminate telegraphing through the veneer,  but at the end of the day, it's no more work than proper prep for a paint job, even when applying textured products.
The BK12 has two small triangular  cavities at the top of the fold and a slightly larger one at the bottom - filling those with BBs,  crushed glass blasting media,  sand etc certainly can't hurt.
As the mouth on this design is forward facing, it won't benefit from boundary reinforcement as do the Hornshoppe,  FH3, or any rear mouth BLH.
Chris Bobiak
Victoria BC Canada
you don't really believe everything you think, do you?
Reply #26 on: December 07, 2011, 05:12:20 AM
Chris,
So is the BK-12 the same basic configuration as the bk-16?  Sounds like it, in which case my recommendation for filling with BBs probably won't do all that much as compared to the sizeable void aat the bottom of the Horn Shoppe horns.
From what many bk-16 builders said, an extra layer of 1/2" or 3/4" ply on the sides was a pretty useful addition, which probably means a 3/8" extra layer on the sides of the bk-12 might be a good thing.
As for the veneer, I suppose whatever each person is comfortable with is fine but I'm mostly trying to stay away from veneer and paint these days myself.
I would still however, stuff the triangular voids with something -- felt, or whatever, just to cut down on resonance, but not having heard this speaker, I don't even know if that is an issue.
I will really just have to get a pair of these -- they really look like they have a lot of potential, especially for te price -- less than $400 total for a sweet liittle floor standing speaker is somethig that has a lot of appeal.
Offline TonyMc
Reply #27 on: December 07, 2011, 12:54:53 PM
I've been looking into the FE126EN too lately. I want to sell off my Axiom M60Ti to build a set of Saburo horns.
I don't know if it's the right step over what I currently own, but I love the way they look and I like the idea of building it with my own two hands.
I keep imagining what the Saburo would sound like with tubes :0)
Offline ralph
Reply #28 on: January 17, 2012, 12:27:38 PM
Hi to all on the forum. This is my first post here. Three days ago, I completed my first speaker build, a pair of the BK-12s. I am very pleased with the sound so far. They just sound great, and the bass is amazing for a 4.5" driver. I am driving them with a home built Zen4 from the PassDIY site - I love the amp, have had it for about 5 years now.  I have a foreplay3 on order to go with the system, no decent preamp now, and the Zen really needs one. The placement and orientation of the speakers in the room is seems critical...but the room is very odd shaped.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fralphhowey.com%2F_audio%2F_images%2Fspeakers-1.jpg&hash=a45401a7ca69f7d8789457c4ed2270b899e07de0)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fralphhowey.com%2F_audio%2F_images%2Fspeakers-2.jpg&hash=384f0bae6e38078d6815ccc6ae31216ac94d7f3d)
« Last Edit: March 18, 2012, 02:18:19 PM by ralph »
Ralph Howey
Taos, New Mexico
Offline Capt.Z
Reply #29 on: January 17, 2012, 12:30:33 PM
Nice work.
Give the driver about 300 - 500 hour break in time to hear the full potential of the speaker.
