OK, good info. You tube is not glowing, nor is it operating - if it were, then the voltage at T21 would be 150v, +/- 5v at most.
The high voltage supply comes in at R7. Inside the 0D3, that is connected to R3, which is then wired to terminal 25. Then it goes through the big resistors to terminal 21. Since you have voltage at terminals 21 and 25, this part must be working, and terminal 21 is supplying power to the preamp circuitry. (If the regulator tube were working, it would shunt some of the current to ground, reducing the terminal 21 voltage to 150 volts.)
Terminal 21 is connected to R5, the positive input of the regulator tube. R2 goes to ground at 24U and 28L. Check these connections and solder joints, especially terminal 28 which has a lot of wires. That terminal requires more heat to get all the wires connected properly, so it's easy to get a poor joint there. You should be able to measure the tube voltages of 0 and 150 at the ends of the 0.1uF bypass capacitor, R2 and R5
