Sum to Mono w/ DPDT
Dr. Toobz · 10108
Offline Dr. Toobz
Reply #15 on: October 30, 2011, 04:32:50 AM
I finally got to play around with the mono switch idea, and I took Paul's suggestion of wiring a SPST switch off the pot (being the simplest approach). This worked perfectly! The folded mono has no loss of bass, no loss of depth....and flipping the switch for an actual mono recording does absolutely nothing, so there's clearly no balance or phase issues between channels on my Quickie (or my sources). The mono switch helps immensely with jazz recordings from vinyl, as the surface noise is much less intrusive when folded down.
Thanks for the advice!
Offline xcortes
Reply #16 on: October 30, 2011, 05:19:58 AM
I've had the switch suggested by PJ
Xavier Cortes
Offline Dr. Toobz
Reply #17 on: October 30, 2011, 05:57:50 AM
I do 100% of my listening over headphones these days, as my tiny, thin-walled NJ apartment makes speaker use a dicey proposition. (My Heresy speakers are hooked up, but haven't seen any action since I sold my condo this summer and moved to the coast). So, it was important for me to have the output over both channels, exactly opposite of what might be preferable over speakers!
Offline Moko
Reply #18 on: November 05, 2011, 03:29:43 AM
Could you post up a picture of your mod as I am having the same problem with my mono Jazz albums and your solution sounds relatively easy to do.
I was intending to add a second arm on my deck dedicated to Mono using something like the Ortofon OM25M cartridge so having a mono output on my Quickie would be ideal.
Thanks in advance
Offline Moko
Reply #19 on: November 29, 2011, 07:07:38 AM
I don't know if I have done the modification right, or I am just not getting what the mono switch should do but here's what I did I soldered a wire off Terminal 1 & soldered a different wire off Terminal 5 to a SP/ST switch so no problem there but if I turn the switch on whilst playing a mono LP the sound becomes much quieter & distorted.
However if I try the same thing whilst playing a Stereo LP the volume remains the same & no distortion, but I do lose half the band (like on Beetle's stereo LP's and on Gene Clark I lose all the backing vocals)
So my question is this what I should expect, or have I done something wrong?
Ideally I was trying to lose some of the surface noise on my Mono LP's when using a stereo cartridge (Denon DL103) so maybe a mono cartridge would be a better way to go.
Thanks in advance for any advice/opinions
