Crack Dimensions
lextek · 6226
Offline lextek
on: December 09, 2011, 04:07:28 PM
I may have just not found it, but what are the dimensions of the Crack?
Bob Lasky
Reply #1 on: December 09, 2011, 04:27:50 PM
The top plate is 6" x 10" (then add maybe 5/8" on each side for the thickness of the  base), and the base is 3-1/2 tall, to which you add the height of the feet -- maybe 3/8" or so.
If you will eventually want to install the speedball upgrade, you'll need all the internal height of the 3-1/2 dimension.  Also helps to leave the base full height for large film caps that people often find to be a nice upgrade. The height does not include the tubes or transformer.
HTH,
Jim
Offline lextek
Reply #2 on: December 10, 2011, 08:24:00 AM
Thanks.  Just planning on where to place the Crack.  Should fit fine.
Bob Lasky
