Crack as preamp
jimiclow · 14252
Reply #15 on: March 10, 2012, 01:22:12 PM
Yes, Crack can work. It was the thing that inspired our past year's research in low output impedance preamp circuits. It's more or less an original Foreplay circuit but with a bigass cathode follower and lower output impedance.
In preamp comparisons we did the Crack was not quite as good sounding as a modded Crack using the 6080 as a voltage amp rather than a CF. That was not quite as good as using a pair of 7233s as the VA. That was not quite as good as using 6EW7s with the big half shunt regulating the small half (hmm or is that the other way around? - can't recall off hand), and to my ear the 300B preamp is at a different level of the game than any of those. All of these had output impedance of 500 ohms or less, and no output transformers.
Offline lextek
Reply #16 on: March 10, 2012, 01:29:53 PM
Now I have to build a Foreplay or Stereomour.  The Crack sounds fine in my heaphone/spare room system.  What do they call that drug that leads to others?
« Last Edit: March 10, 2012, 01:32:01 PM by lextek »
Bob Lasky
Offline porcupunctis
  • 0D3
Reply #17 on: March 11, 2012, 10:22:56 AM
It's a "Gateway" drug.  I suspect that is what the Quickie is.  At least it worked that way for me.  Seemed innocent enough at first.  Then it was Foreplay, SEX, Paramours, Crack, Seduction, and now I'm on to Paramounts and a second SEX.  I'd find a 12-step program if I really wanted to quit, but I don't.
Randall Massey
Teacher of Mathematics
Offline Laudanum
Reply #18 on: March 11, 2012, 03:50:53 PM
I built Crack, Seductiona and FPIII and stopped there. No amp/amps.  The scary thing is that I already do have a couple pairs of speakers that are easily efficient enough for the amplifiers.  So maybe I should say no amp/amps ... yet.
Desmond G.
Offline AllanMarcus
  • Mainlining my way to bliss
    • My DIY Site
Reply #19 on: May 31, 2017, 12:20:51 PM
I'm gonna reopen this ancient thread. I'm going to try the Crack as a preamp with a simple 1/4 to RCA cable, but assuming I like it, I will want to wire in. Is the bast place to tap the crack as a preamp at the headphone jack, or might it be best tapped between the tubes? I have the speedball installed.
This space for rent
Reply #20 on: May 31, 2017, 02:29:23 PM
Take the output from the jack.
Offline mightygrey
Reply #21 on: May 31, 2017, 07:52:56 PM
Tried my newly-finished Crack as a pre-amp upchain from on old 20wpc NAD 7020e, sounded awesome.
Tried using it as a pre-amp on my Sherbourn PA 2-250 (250wpc) power amp, and immediately had an incredibly loud humming noise come out of my speakers, even with the volume pot at zero. I was running a Schiit Mani pre-amp in front of the Crack from my record player.
Any thoughts as to what might be happening here?
Matty
Reply #22 on: June 01, 2017, 10:18:30 AM
This sounds a lot like a ground loop hum.  I find it odd that the Sherbourn only has a 2 prong power cord, is the NAD a 3 prong cord? (I can't find an image with the AC plug included)
Noises like this can often be arrested by connecting a piece of wire between the metal plate of the Crack and the metal chassis of your amp.
Offline mightygrey
Reply #23 on: June 01, 2017, 12:55:00 PM
Thanks Paul - I'll check this out after work this afternoon!
Offline AllanMarcus
    • My DIY Site
Reply #24 on: June 02, 2017, 03:32:01 PM
so I'm a little confused. the female jack on the crack had 6 pins. See the picture:
(https://anonimag.es/i/jack13632.jpg)
lug 1 is obviously common
lug 2 and 3 are right and left into the amp
I assume lugs 4-6 are mirrors of 1-3, but only when there is no plug inserted, but all these lugs are connected to gound, and to the hots via the resisters. I guess I would love to hear an explanation of what's going on here (pop protection?). I would also like to know if I want to use these lugs to as taps to feed RCA jacks for preamp use, what do I need to do and what will I be giving up.
or should I just come off 1,2, and 3 for the RCA preamp jacks?
Thanks.
« Last Edit: June 02, 2017, 07:05:54 PM by AllanMarcus »
This space for rent
Offline diynewbie
Reply #25 on: June 05, 2017, 09:43:42 AM
Yes, connections from 1 to 4, 2 to 5 and 3 to 6 exist when no plug is present and the connections are broken when a plug is inserted.
While you could make changes to the wiring, but why not just buy or make a TRS to RCA connector instead?
While I could give a guess as to “what is going on here”, I think it would be best to leave it to the knowledgeable.
I will just say this is a modification of the original wiring (no 4-5-6 connection) and it eliminates a voltage swing of up to ~ 9 volts then back to 0 measured from tip or ring to ground when the Crack is first powered on with no headphones attached.
Offline AllanMarcus
    • My DIY Site
Reply #26 on: June 07, 2017, 03:07:38 AM
I added pre-outs to the crack. Sounds pretty nice. The wiring simply comes off the headphone tap (1, 2, and 3 in my pic above), so something needs to be plugged into the headphone jack for the pre out to work. I use a simple 1/4" to 1/8" adapter to serve this purpose.
I prefer the jacks as I think it's cleaner than a 1/4" to RCA cable.
(https://cdn.head-fi.org/g/9933770_l.jpg)
This space for rent
Reply #27 on: June 07, 2017, 06:14:47 PM
I like that solution, sort of like an arming pin :)...John
Reply #28 on: June 08, 2017, 08:54:24 AM
You'll have to cut the connections between pins 4, 5, and 6 on the photo you posted, or just use a 1/4" TRS to RCA adapter in the headphone jack.
Offline AllanMarcus
    • My DIY Site
Reply #29 on: June 09, 2017, 05:13:42 AM
Thanks PB. Can I ask, what am I giving up by cutting that connection?
This space for rent
