Eros Output Caps
Grainger49 · 27120
Reply #30 on: September 07, 2013, 05:05:10 AM
A Care Package arrived this week.  I had ordered two pair of caps two months ago.  I forgot, completely forgot.
I am now burning in two TFTF V-Caps, they are due off on the 22nd.  Then into the Eros!
« Last Edit: May 04, 2014, 01:40:52 PM by Grainger49 »
Offline corndog71
Reply #31 on: September 07, 2013, 05:59:46 AM
You're in the deep water with the big kids now. :)
Rob
Offline debk
Reply #32 on: September 07, 2013, 06:02:56 AM
Grainger
What value capacitor did you go with?
Deb
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #33 on: September 07, 2013, 07:32:36 AM
Rob,
Well, I was making money then and it was a weak moment.
Deb,
0.47uF.  That is the design value for the last stage; same as the Seduction.  The values delivered, there have been two different values I am aware of, are a upgraded film Solen caps.  Upgrade sonically from the brown metalized Polypropylene film caps delivered in the Seduction.
« Last Edit: May 04, 2014, 01:41:13 PM by Grainger49 »
Reply #34 on: September 13, 2013, 10:10:33 AM
I check the connections to the TFTF caps every day.  The two cats sleep in this room and they are awful about messing things up.  So far, so good.
« Last Edit: May 04, 2014, 01:41:37 PM by Grainger49 »
Reply #35 on: September 13, 2013, 06:43:45 PM
I should have warned you about the catnip impregnated caps...John
Reply #36 on: December 16, 2013, 03:45:24 PM
Bump.   ....you need to finish the story :)
Reply #37 on: December 27, 2013, 12:13:34 PM
Sadly... I have not done a comparison yet.  The Caps are burned in and ready.  But I have many other things, house/personal, that have come before my listening.
Maybe soon.  I'm sick as a dog and not ready to do anything physical.
« Last Edit: May 04, 2014, 01:41:54 PM by Grainger49 »
Offline johnsonad
Reply #38 on: December 27, 2013, 01:17:20 PM
I put the 0.47uF TFTF in my Eros (tape) and am very happy with the results.
Reply #39 on: December 29, 2013, 11:17:14 AM
Well keep us posted when you do get to them ;)
..and get well soon!
Offline johnsonad
Reply #40 on: January 04, 2014, 02:23:03 PM
I move the V Cap Teflon's from my Eros tape to the Tube Phono replacing a pair of Auricaps. The difference was immediate and I'm kicking myself for not doing it earlier. The Auricaps are great but I'm a detail guy and the Teflon's seem to get  a little more out of what's already there.
Offline Dnorris
Reply #41 on: March 21, 2014, 12:08:12 PM
I'm starting a new Eros build (stock first, of course), but have a pair of .47uf audio grade film capacitors that I want to try as well. To clarify, it looks like the design value for the output stage caps is .47uf as per Grainger's post, the parts checklist & schematic show 1.0uf and the included kit caps are 1.5uf. Am I correct in assuming the .47uf would work fine, just changing the bass rolloff point somewhat? Thanks in advance.
Dale Norris
Offline Dnorris
Reply #42 on: March 21, 2014, 12:17:14 PM
Oops, Sorry, forgot to add my name to my initial post.
Dale Norris, located in the Kansas City area. Built a Crack + Speedball with some tube rolling last year. Very happy with that indeed, spectacular sound with HD650.
Dale Norris
Reply #43 on: March 21, 2014, 12:45:10 PM
Yes, your statement about the low frequency performance is correct.
At the time that we put out the Eros, we had the 1.0uF Solen capacitor in our inventory for the SEX amp of that era.  When selecting the coupling cap for the Eros, we simply used the 1.0uF Solen because it was already in the inventory and it is a nice sounding cap.
Currently, the SEX parafeed cap is 1.5uF, so that ships with the Eros as well.
Reply #44 on: March 22, 2014, 06:40:05 AM
To add a bit here - the output stage of Eros is the same as Seduction (now Reduction). The original Seduction had a 0.47uF cap, which could work with load as low as 15Kohms, but with a trace of deep bass loss, -3dB at 22.5Hz. With Eros, we wanted an upgrade in performance and parts, and the 1.0uF Solen seemed appropriate.
