SR45 amplifier
debk · 221508
Reply #285 on: June 17, 2013, 02:50:30 PM
PJ is indeed out of town at the moment.
Offline johnsonad
Reply #286 on: July 07, 2013, 12:50:43 PM
With everyone back this week, how about an update on the status PJ?
Aaron
Reply #287 on: July 07, 2013, 02:36:49 PM
Status? Same as when I left town. (Just got back last night  :^)  Ask next week - I hope to get some time on this project. There's a lot done in my head that isn't written down or sketched out yet.
Offline johnsonad
Reply #288 on: July 13, 2013, 08:16:53 AM
Not quite a week but close enough:) how's it comming along Paul?
Reply #289 on: July 13, 2013, 01:43:11 PM
Got some time Thursday and today, and finally got a lot of my thoughts down as actual schematics with parts values (!). Four pages and counting. I've also tentatively laid out which functions go where on the new physical layout, so I can draw the actual wire bundles. Once that's done, I can start doing the detailed PC boards. (Don't worry, all the signal voltages are off the boards - it's just power supplies and sequencing logic.)
One of the things going into this design is an RFI filter at the power input; I'm following Buddha (the late John Camille) in using a commercial RFI filter followed by a homebrew lower-frequency filter that gets down to 2kHz. I've gone back and forth on how to do this, and how complex to let it get, but that's where I am now.
The power and protection sequencing was a bear since I didn't want to use digital counters. At this point there are four LV regulators and three relays in each amp. I had worked it out a month or two ago, but getting the details down on paper (and fixing my hand-waving!) was a chore.
Offline xcortes
Reply #290 on: July 13, 2013, 02:13:12 PM
I'd better start saving!
Xavier Cortes
Offline johnsonad
Reply #291 on: July 13, 2013, 02:52:20 PM
Me too! I'm getting more excited about this project with every update. Thanks for not giving up on it Paul!
Offline johnsonad
Reply #292 on: July 28, 2013, 06:36:34 AM
It's time for the two week status report. How's it coming along Paul?
Reply #293 on: July 28, 2013, 10:47:13 AM
Good progress this week - as usual, once I see the circuit and/or layout on paper, I make changes ... Hope to get some PC boards laid out this next week or two. I need to mock up the power supply to confirm voltages and delay-relay sequencing, before getting into the actual audio circuit - but I'm already looking at some options for the driver bias.
Offline johnsonad
Reply #294 on: August 04, 2013, 03:25:29 AM
It's been only a week but how about an update Paul?  You seem to be moving along on this project.
Reply #295 on: August 04, 2013, 02:55:21 PM
No update today; too much real-life business.
Reply #296 on: August 07, 2013, 12:19:17 PM
OK, a bit of progress finally. Today I ordered two chassis plates, on which to build the prototype pair. Since this required enough certainty in PC board layout to position the mounting holes, which in turn means finalizing the specific parts to be used, that's actually quite a bit of work - but Front Panel Express has a sale that I didn't want to miss! The plates were $180 on sale, FWIW.
Offline johnsonad
Reply #297 on: August 07, 2013, 02:25:06 PM
Thank you very much for the update Paul!
Offline xcortes
Reply #298 on: August 07, 2013, 06:32:13 PM
I've started refining my horn system. Having had it off for a few weeks has helped me realize where a couple  of improvements could be made, mostly positioning and crossover related. I will still modify the three pairs of Paramounts to use one Co, one Ni and one series feed with Ag primaries and secondaries with the WE. And when I install the horns back, hopefully early next year, they will be powered by three pairs of these new sr 45s!
Pd. Please Paul, when designing keep in mind my tl404s!
Xavier Cortes
Reply #299 on: August 13, 2013, 03:31:06 PM
"I'm sorry, Xavier, I can't do that. Opening pod bay doors ..."
Seriously, the chassis is laid out for the OT-2 and OT-3; there's enough room for a TFA-204Senior but that's it. Since I don't have drawings for the TL-404, I can't say whether it will fit or can be oriented correctly.
Of course a custom chassis plate is always an option. Not an inexpensive option, since it would not be laser-cut, but an option. Let's get something working before we start to re-design it for different parts!
