Question about levels on my amps
SilverS · 2334
Offline SilverS
on: July 03, 2012, 07:41:52 PM
So I have a Quickie and S.E.X. and each has its own volume knob. What is the best configuration for maximum sound fidelity:
Quickie turned up higher than S.E.X. or S.E.X. turned up higher than Quickie?
Reply #1 on: July 04, 2012, 04:30:03 AM
Often asked, answered differently.  The real answer is you play with it to get the lowest noise.  Often it is with the preamp (Quickie) all or almost all the way up and the amp making the fine adjustments.
But seriously, it is however you like it best.
Offline SilverS
Reply #2 on: July 04, 2012, 07:57:15 AM
Offline saildoctor
Reply #3 on: July 04, 2012, 08:23:59 AM
There is a nice writeup by Paul J in the technical forum called 'Signals, noise, and signal to noise ratio'.  It's a sticky near the top.
Kerry Sherwin
45 Paramounts, 6SN7 Extended FPIII, OC3 regulated Seduction
Blumenstein Orca Deluxe / 2x Orca Subs
VPI Classic / ADC CD-100x
