Tube power supplies
Guest · 5186
4krow
on: August 08, 2012, 04:37:09 AM
When considering a tube power supply, I thought everything was great as long as you have adequate voltage and amperage. With this idea in mind,  I replaced a power supply for a Musical Fidelity X10 V3 unit. Next thing I know the unit is pissed at me and blows the output transistors(it is a hybred unit). Then, no voltage on the rails. But the strange thing was, after I replaced the abused transistors, voltage was back. Of course, I don't have a schematic so shootin in the dark is the norm here. And when I measure the power supply disconnected from the circuit, it reads 14V (it is center tapped, and both sides read good). As a parting note, I will admit that there could easily be something amiss else where, since I replace almost every component in this unit, thinking it would be golden afterward.
Reply #1 on: August 08, 2012, 05:48:37 AM
Greg,
With most power supplies, if you don't draw much current the voltage floats high.  Did you measure the voltage you ended up with?
4krow
Reply #2 on: August 08, 2012, 07:26:23 AM
Didn't get a chance yet. The first time around, it was over before I knew what. I did try the original power supply, and things seemed ok. So that is why I wondered about this.
Offline mrarroyo
Reply #3 on: August 08, 2012, 12:18:17 PM
Is your new PSU 12-0-12Volts AC 30VA (24VCT)?
Reply #4 on: August 08, 2012, 01:39:27 PM
I'm with MrArroyo,
Knowing what the end point is, is important.  Do you know what open circuit voltage the power supply puts out?
4krow
Reply #5 on: August 08, 2012, 03:15:15 PM
As I mentioned in post #1, the open circuit voltage is 14-0-14V. The circuit requires only 500ma, and off hand I don't recall the specs of the torrid that I used. But I will say that it was much heavier than the original transformer.
Reply #6 on: August 09, 2012, 01:12:52 AM
You can use a pair of three pin regulators to hold the output to 14-0-14V.  As long as the circuit doesn't draw more than specified current, and the regulators can handle a half an amp, you should be in high cotton.
4krow
Reply #7 on: August 09, 2012, 10:29:08 AM
So, could an MJE350 do that, cuz' I think that is what is in the circuit presently. I will check this stuff out before posting further. This poor unit actually worked when I got it, but I don't know how! It had burn marks on the circuit board where the output transistors were, and the RCA jacks were hit and miss for contact. oh boy..
Reply #8 on: August 09, 2012, 11:16:01 AM
The MJE 350 is not what I had in mind.  A variable regulator is like the LMJ 085 used in the Eros as a variable positive voltage regulator.
As Desert Pete said, "Have faith my friend,"  I'm not going to say that there is water down below.
