C/4s original SEX ,voltage questions.
najo49 · 64124
Offline najo49
Reply #15 on: September 13, 2012, 04:33:14 PM
Paul, I got everything wired as per your instructions. Two things the 3w 6k gets hot! And there is no sound,at all. I am using the original output trans. . The out put from pin 3 goes to the orange wire on top mounted trans. and also thru a 3.3uf solen cap and on to the orange lead of the outpt trans.Does that snd. right to you? All the LEDss light up on c4s and the output voltage into c4s is 298v. I have checked and double checked but now have reached a point I thought I would seek your help. J.
Jann Olsen, [email protected].  Lowther medallion 2 with pm2a./ extended foreplay lll,/EROS phono /Grado ref/ SOTA star Vacuum SME V, /  45 amp direct coupled,c4s,mQ nickel  / paramour  2a3 w MQ iron /Original SEX monos /Jena Cables /heathkit wm6a/ proAc Tablette 50 sig , with push pull
Reply #16 on: September 13, 2012, 06:07:45 PM
Yes, the 6K will get pretty hot. I would have chosen a 5 watt resistor, today, but that was the design back then and I didn't want to invent yet another design! The hotter that resistor, the less hot the C4S transistor, and hence the longer it will life. :^)
So far as I can tell, there is no reason it would not work if it is wired as per the circuit in ref 3) with the small changes I suggested. I don't think I actually specified that circuit myself; I thought you were asking for wiring applicable to the TFA-204. So there's no way for me to tell exactly how it is wired now. Perhaps if you ran the tube voltage checks again I could uess whether the tube part is working as expected. Better include the voltages on the four wires of the original output transformer (now the plate choke and cathode feedback coil). The current parafeed output transformer probably has a label which will identify the wires by color; they are not standard and of course I don't remember the color code used 13 years ago so tell me which wire goes to where and I'll see if that makes sense to me. Best I can do at this distance.
Offline najo49
Reply #17 on: September 15, 2012, 09:59:10 AM
Paul, I have wired the amp in parallel feed is that the right term? I have two questions 1. the 6k 3w is running very hot and seems ready to go up in smoke at any time. It is putting out 298v to the input to the c4s. and it is putting out the proper 225V at its output. My voltage after the input chock are high 453 compared to the 410 or so I would rather see. Thats running on a varic at 117V. I am running the original output transformers as my  204s have not arrived. I am not getting sound out now. Is this because I can not get sound until I get the new transformer in? I will just give you the discription of my transformers as they are wired now. The orange lead to top trans comes from pin 3,the lead to the output trans goes from same pin 3 thru a 3.3up solen to orange lead of this smaller under mounted small trans. the output come from this small original output trans. to binding posts. j
Reply #18 on: September 15, 2012, 10:32:01 AM
Some basic electrical calculations.
You can get the power dissipated in the resistor by first getting the voltage across it.  Measure the voltage across the 6k resistor.  Power is V2/R, that is the voltage squared divided by the resistance, 6000 ohms.
You want the resistor to have some headroom since it is under the hood.  So if it is a 3W resistor and it is dissipating 2+ watts then you can get a 5W resistor to replace it.  A 5W resistor will run cooler and the temperature under the hood won't derate the power rating to below what it can sustain steady state.
Reply #19 on: September 15, 2012, 11:56:25 AM
That's not enough information for me to work from. See my previous post.
Offline najo49
Reply #20 on: September 16, 2012, 06:25:55 AM
Paul, I will not take anymore of your valuable time. I will end by giving you the current transformer wiring. upper xformer ,    Red  is from high voltage of power supply. blue lead comes from pin 2 orange connects to pin 3, . green from upper, goes thru a 220 uf, electrolytic bypassed with a 270K resistor to gnd. the small output has a connection from pin 3 thru a 3.3 solen to the orange lead. bl.,brn,red,yel are not connected. Out put to binding posts is via blk. and 16 ohm yel. to speakers. I am going to have to wait several weeks for the x formers the tfa 204s to arrive. Thanks you so much for your help,I have really learned alot,and as you have noticed I have alot to learn. You are so kind to share your knowlege with me. J.
Offline najo49
Reply #21 on: September 17, 2012, 07:11:04 AM
grainger, Thanks for your input. I see the ohms law, and I appreciate the heads up. I have now got that sorted out.The amp does not produce sound ,and I assume thats because I have converted to parallel feed,from the original mu follower. and the original output cannot work. I am waiting on a pair of tfa 204s,but I wanted to listen to it until the new xformer arrives.
Reply #22 on: September 17, 2012, 07:19:56 AM
Hey!  I put the 10 year old C4S boards into my FP 2 a few months back.  I got the incoming and outgoing voltage leads swapped.  It drove me nuts!  (short trip!)
I spent a couple of hours reversing the LEDs.  To no avail.  Then PJ got my head straightened out and it sounds awesome!
I had to turn down my sub by a couple of clicks.  Maybe I should turn it down another.  The bass is much firmer and extended.
Reply #23 on: September 17, 2012, 10:29:53 AM
It's no problem, I am genuinely interested in seeing you get this thing working. Sometimes I make short answers when I'm in a hurry, so apologies if I seemed curt.
The reason I asked for tube voltages is to be sure all four tube sections (two per tube) are operating correctly. The high voltage (453 vs. 410 expected) might be caused by one section failing to draw enough current. Check the voltages at the actual tube socket pins, don't rely on wires that connect one socket to the other - there could be a bad connection or a broken wire.
The old output transformer (now the plate choke with feedback coil) appears to be connected correctly. I assume the "270K" resistor is actually 270 ohms? I would encourage you to raise it to 390 ohms, 5 watts. The higher wattage will give a longer life, and the higher resistance will reduce the total current through the plate choke, reducing its distortion.
From your description, there is only one lead of the small output transformer connected, so it's no wonder there is no sound. The 3.3uF Solen should go from pin 2 of the tube socket (NOT pin 3) to the orange lead of the transformer (I assume that it the lead marked "1.25 watts" on the transformer). The black lead of that bundle is shown in ref 3 going to ground.
Your numbers show 155 volts across the 6K resistor (453-298), which by Ohm's Law would be about 26mA current. This would be 4 watts dissipation, exceeding the rating - no wonder it is hot! Best to check the resistance in case the heat has damaged the resistor. I would encourage you to replace it with a 6K 5watt resistor - but not until we get the high voltage down to where we expect it to be. But the circuit says you should have only 18mA (total of 16mA to tube pin 5, and 2mA through the three 50K resistors on the PC board). The plate voltage is close enough (225v vs. 250v expected) so I expect the 16mA is correct - leading me to suspect the 50K resistors may not be wired in series. The old boards were very confusing in that area, so it's worth inspecting them. There should be three resistors in series, with 100v across each one (adding up to 300 volts across the string).
Incidentally, I do recognize how much of a pain it is to be entirely clear and complete in posts like these, where we can't see what the other is doing. But we are usually successful eventually!
Offline najo49
Reply #24 on: September 19, 2012, 07:27:39 AM
Paul, Thanks,I just thought you must become tired of dealing with a beginner. I am now retired,a musician ( string bass) playing with various Orchestras . I am tryi ng to learn enough to partially at least design a few things. And I have quite a collection of tube amps. I have a Heathkit wm 6, 70w push pull, ever seen one? They are very rare only 2 k were built.But I have many others all rebuilt by me.
I am waiting on the 204 x formers. But I did something fun with the sex amp that is working and still wired in the first version. I have a transformer,it is 117v primary and a pair of 19v secondaries  and a pair of 7.5 v secondaries. I hooked it up in the place of the original transformer. primary to the 3.3 up cap output and the other lead grounded to sex gnd. I used the 19v secondaries on gnd. and the other as the positive out put. And to my surprise GREAT things came out. It had more power, I do not know how much but it was a big improvement on the original trans. And no feed back except what the chock adds. Why does this work?It has a oval magnet structure and the windings on each side of the oval. And I tried the 7.5 outputs and they sounded pretty much the same. I have no idea what the output resistance is but I thinkk the 19v outputs sound best. What do you think. J.
Offline Hank Murrow
Reply #25 on: September 19, 2012, 10:14:42 AM
I am now retired,a musician ( string bass) playing with various Orchestras . I am trying to learn enough to partially at least design a few things. And I have quite a collection of tube amps. I have a Heathkit wm 6, 70w push pull, ever seen one? They are very rare only 2 k were built.But I have many others all rebuilt by me.
Dear J; Indeed, I remember that Heathkit 70watter, because I built one back in the days of mono when I was 15 or so and drove a Stephens 15" coax loudspeaker in a Voice of the Theater system I built myself. Hey, it could be heard on the ridge a half mile distant from my parents' house! Think "Night on Bald Mountain" in the balmy California evening air..... Went on to Dynakits until they went solid state, but now Bottlehead Customs has built my Final Music System, and with Orcas & BUF Subs I am a very happy camper. Just hoping I get a couple more decades to enjoy it.
Cheers, Hank
Offline najo49
Reply #26 on: September 21, 2012, 03:58:44 AM
Hank, I use a pair of altec speakers for my low power system, the 15 ohm vintage 15 inch woofer, horn and driver. I can not imagine what a 70 watt speaker would do with them, loud !. I love my wm 6s and I have completely restored them,paint,teflon wiring ,all the resistors and caps . They look like new and and hands down the best push pull I have ever heard,they are paired with the proAc 2.5s or the pro ac tab 50 sigs in my high power system. Thanks for you reply, j.
